Sponsored by: Real Truck
ring and pinion slop
Old Sep 28, 2008 | 05:53 PM
cattlerancher's Avatar
cattlerancher
Well i noticed kind of a klunk comming from the rear axle when i shift between 1400, and 1700 rpm. so i stopped left the truck out of gear and i can move the drive shaft maybe 3/8 of an inch before it catches. The funny thing is when i take it over 1700 rpm then shift it doesnt do it, i did take the oil fill plug out and it had a little bit of metal but not much. any ideas? thanks
Old Sep 28, 2008 | 07:00 PM
aldridgec's Avatar
aldridgec
The better spec is the amount of ring gear movement, or pinion bearing slop. 3/8ths doesn't sound hateful but I've never really paid any attention to an exact spec on the input side. I would just be guessing at saying that sounds ok. I know my truck drifts a fair amount because of the slack in the axle and I know my specs are fine. Do you have a long wheelbase truck (over 156 inches)?
Old Sep 28, 2008 | 07:04 PM
cattlerancher
the truck is a 00 f 350 4x4 s/c dually 6 speed with the psd, and 4:10 gears not ls. thanks for the reply that makes me feel better.
Old Sep 28, 2008 | 07:12 PM
2stepn's Avatar
2stepn
I agree 3/8" probably is ok. When turning the drive shaft you're seeing the play that exists in the axle side and pinion gears which can seem excessive. To really get an accurate measurement you would have to remove the diff. cover and measure ring and pinion backlash.
Old Sep 28, 2008 | 11:23 PM
aldridgec's Avatar
aldridgec
Yeah, definitely with the larger ring gear I would say that amount of play is ok, even nominal. It would really surprise me if the rear was making the banging noise between shifts and it wasn't the slip yoke or a u-joint.
Old Sep 29, 2008 | 08:19 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
3/8" is about right, for a non-LS unit. The spider gears have some slack in them and that's probably most of the "give".
The small amount of metal is OK too, my '01's rear-end had some decent size "crumbs" at about 5K miles and it's still holding together 7 years later
I'd check the u-joints, and the hanger bearing if you have one. Sounds like a bad u-joint.
Redneckryder
1997 - 2003 F150
17
Mar 22, 2013 10:09 PM
Steve Spano
Aug 2, 2012 08:27 PM
Damonkr
Jan 19, 2011 07:24 PM
Joms
Apr 17, 2008 06:27 AM
kc2006
Feb 18, 2005 11:27 PM
