Ignition stuck
Old Sep 28, 2008 | 04:01 PM
benbe71's Avatar
benbe71
Ignition stuck
My ignition is stuck in the ON position in my truck lucky that it happened when I got home. The past few weeks on and off it has been hard to turn the key to the off position. When it was stuck on the on position I popped the hood and had to pull the wire off the injection pump to shut it off. I pulled the ignition cylinder out and that works fine its what the cylinder goes into that's jammed anybody know what this part is called? or is there a way to unjam it?
Old Sep 28, 2008 | 07:54 PM
JOHN CHAPPELL's Avatar
JOHN CHAPPELL
I just got done replacing it it is called the actuator and I just bought one from car quest for 14.00dollars not to hard to replace does you truck have tilt?
Old Sep 28, 2008 | 07:56 PM
benbe71's Avatar
benbe71
No it does not have tilt how hard was it to replace?
Old Sep 28, 2008 | 08:09 PM
JOHN CHAPPELL
not very hard the hardest part is getting the broke piece out of the collum shouldn't be to tuff with out tilt. pull steering wheel turn signal switch drop steering collum down you should be abel to see the actuator
Old Sep 28, 2008 | 08:10 PM
benbe71's Avatar
benbe71
Alright thanks man.
Old Sep 28, 2008 | 08:12 PM
JOHN CHAPPELL
your welcome
Sunline Fan
Aug 23, 2022 06:13 AM
snook715
413
Nov 2, 2015 05:36 PM
F-750pickup
Ford Truck Parts for Sale
Mar 24, 2014 02:19 PM
snook715
Mar 14, 2011 04:37 PM
benbe71
19
Jul 21, 2010 11:30 PM
