Update on my progress
Old Jul 14, 2010 | 11:07 PM
benbe71's Avatar
benbe71
Its taken forever to get to this cause of those damn rusty clips on the front end Tomorrow i'm gonna pull the transmission out, I got all the hoses and wires disconnected. Here are some pics.
And one of my old truck for fun
Old Jul 14, 2010 | 11:10 PM
poocher pup's Avatar
poocher pup
Long way to go but have fun it's all worth it in the end.
Old Jul 19, 2010 | 02:54 AM
oreocreaming's Avatar
oreocreaming
what exactly are you doing to the truck?
Old Jul 19, 2010 | 11:33 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Sorry, Deleted ... Wrong thread !
-Enjoy
fh : )_~
Old Jul 19, 2010 | 05:55 PM
benbe71's Avatar
benbe71
Pulling the engine, gonna take it apart to see if its salvageable, can you tell me if it'd be easier to take off the transfercase and transmission to pull the engine or all in one piece?
Old Jul 19, 2010 | 06:03 PM
swooshcmk's Avatar
swooshcmk
What transmission?
I could barely get my C6 2wd transmission out attached to the engine. I doubt I could have gotten a 4wd with transfer case out. The problem is you have to lift the engine up to get the oil pan to clear the front crossmember and then your transmission is hitting the cab, so you have to tip the whole engine front up/rear down ... kind of a pain.
Old Jul 19, 2010 | 06:04 PM
oreocreaming
its easier to just unbolt the engine from the tranny and pull the engine. if you loosen the 2 bolts on the transmission mount then you can slide it back about an inch. that will help big time.
Old Jul 19, 2010 | 06:51 PM
benbe71's Avatar
benbe71
Ok thanks much i'll let you know how it goes. I was just afraid of bending the input shaft on the transmission.
Old Jul 19, 2010 | 06:59 PM
oreocreaming
you'd never break that thing man. If you don't scoot that tranny back the inch then the pressure plate fins will hang up on it a little. Once it's moved you'll be alright. Thatsassuming you have the mitsubishi starter (long) if you have the short then you don't have to slide it back. t
Old Jul 19, 2010 | 11:01 PM
Festus Hagen
Methanoholic
Remove starter, Separate transmission from motor at bell housing, remove the top 4 bell housing bolts, break the two bottom bolts loose, leave them for now.
Attach lift to motor, lift motor until bell housing hits floor (no body lifts), place jack under transmission, remove two remaining bolts, It'll come out no problem.
-Enjoy
fh : )_~
Old Jul 20, 2010 | 07:15 PM
benbe71's Avatar
benbe71
i have a pretty long starter, if i remove it i dont have to slide the transmssion back?
Old Jul 20, 2010 | 07:54 PM
oreocreaming
right. if you had the short starter or if you removed it you wouldnt have to scoot the tranny back.
Old Jul 20, 2010 | 08:12 PM
LCAM-01XA's Avatar
LCAM-01XA
I'd remove the starter anyways, just one less thing to get in the way then.
Old Jul 20, 2010 | 10:38 PM
Festus Hagen
Methanoholic
Remove the starter ... The starter will hit the cross member before the input shaft clears the pressure plate.
-Enjoy
fh : )_~
Old Jul 21, 2010 | 01:36 PM
Black Smoke '88's Avatar
Black Smoke '88
do you have to pull the front clip off or does that just make it easier?
