I Need Help Please N Fast!!!!!!!!!!!!!
Sep 28, 2008 | 11:47 AM
I CAN GET A REALLY GOOD DEAL ON SUM B F Goodrich All Terrain LT 315/ 75R 16 Tires ............
MY QUESTION I REALLY NEED HELP ON IS WILL THEY FIT ON A
2002 F150 V8 TRITON XLT EXTENDED CAB TRUCK.
WITHOUT RUBBING ARE MESSING UP THE TIRE HOUSING,.,..
PLEASE IF YOU KNOW THE ANSWER TELL ME ....
Sep 28, 2008 | 11:55 AM
first off, is your truck a 4x4?
if so, you will want a 3" body lift if you get them.
but i know you can fit them without a lift but it is a TIGHT fit and you will have to do some trimming and crank your torsion bars.
Sep 28, 2008 | 12:02 PM
sadly it is not a 4x4.
will they still fit its a 4x2
get back to me plz
Sep 28, 2008 | 12:06 PM
No, they wont fit your stock truck
the only way you will fit those tires is if you get a 3" body lift and a 3" suspension lift.
or get a 7.5 suspension lift.
Sep 28, 2008 | 01:05 PM
Those wouldn't even fit a 4wd without rubbing.
Sep 28, 2008 | 02:21 PM
You need a 3" lift to fit them.
Sep 28, 2008 | 05:45 PM
i know they will rub, but only on the front valence and maybe on the lower A arm at full lock.
Sep 28, 2008 | 08:45 PM
well thank ya'll for the answers..
one more question if i may what is the biggest size i can go then without any mods..
(the tires will be on 16inch rims) but what is the bigest tire size i can go.. like 275 70 16r ...r what??
Sep 28, 2008 | 09:09 PM
Sep 28, 2008 | 11:13 PM
I used a set of take offs from a 02 lincoln navigator on an 02 F150 rwd truck and they are P275/60R17 and they fit just fine without rubbing.
Sep 29, 2008 | 08:06 PM
my 315/75/16's rub, i had to cut my plastic on my front bumper. And they still rub at full lock. Ive also got a 4x4, 3" body and cranked T-bars.
