Offroad & 4x4
Column to floor shifter...........
Old Sep 28, 2008 | 11:20 AM
T.McG's Avatar
T.McG
Who has put a floor shifter in a F250/460/3sp auto/4x4? What did you use, any pics? I have bucket seats with no center console or seat.
Old Sep 28, 2008 | 01:12 PM
75F350's Avatar
75F350
Most trucks are very inconvenient when it comes to installing a floor shifter. Most small shifters are short, and when mounted can be pretty low, and not very comfortable to use.
A company called Lokar;Lokar: Shifters and Shifter *****
Has a veriety of shifters that mount on the trans, or can be remote mounted.
The cable activated shifters are not available for Fords, go figure, but can easilly be upgraded and modified with a B&M bracket package. The Morse cables mount the same, and these brackets are available through B&M.
Not sure what look you are after, but roll cages can be modified to mount the shifter to.
Here is an example of a 79F250, since you were looking for pics;
Image of Cage mounted shifter - Photobucket - Video and Image Hosting
I am sure this may not be an option for most, so unless you have a box, or mount made to mount the shifter above the floor, the Lokar might be an alternative.
Old Sep 28, 2008 | 03:21 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
I have seen it done when the linkadge in the colum goes bad....
I dont think it would be to difficult... But ill see if i can snap some pics next time i see the truck....
Could be several days though.
Old Sep 28, 2008 | 04:58 PM
T.McG's Avatar
T.McG
I'm open to most anything right now. I have the option to mount it however I want since nothing is in the way above the floor board. I will use the truck to plow snow with and the floor shifter is much easier to use than the column one. I had a cheap Auto Zone floor shifter on my '77, I put a 6" extension on the handle to make it easy to reach but just sold the truck. It worked pretty good but would like something a little better if possible. Something with a short handle, like in that pic. might work better. Doesn't have to be fancy.
Old Sep 28, 2008 | 05:10 PM
Truckin4life
I would make a console or something then mount the shifter up to it.
The one i seen was kinda rigged to work for the time being....
If your looking for something thats easier to use. DO something like the lokar and build a custom console to mount it one. For ease of operation...
amsnss
Feb 9, 2014 06:16 AM
billest
Oct 24, 2013 08:28 PM
skotyg
Sep 12, 2013 06:08 PM
TrippingCobras
Jun 28, 2012 09:37 PM
lakecityg
Aug 29, 2011 03:45 PM
