Sensor Question
Old Sep 27, 2008 | 09:25 PM
Alex332's Avatar
Alex332
Sensor Question
Does the 6.0L have a sensor for EGT.
I was going to get gauges but I figure if I get a Banks PDA or the Edge tuner, I can monitor anything that I want to.
I plug in a Snap-On scanner into my truck once but didnet see the EGT, saw everything else.
Thanks.
Old Sep 27, 2008 | 10:20 PM
riggz's Avatar
riggz
No the 6.0 doesn't have an EGT sensor. You will have to get an aftermarket. If you value your truck steer clear of Edge. Get a SCT Xcal2 or Xcal3 tuner. If you like the look of the Edge you can get a DashHawk with an EGT probe for about $400. I work with a guy who talked highly of his Edge in his 6.0. His motor just blew up last week.
Old Sep 27, 2008 | 10:58 PM
Alex332's Avatar
Alex332
Im not looking to make power, and I also know about all the 6.0L issues with tuners.
If I did use a tune I would only be using the Econ mode. Just looking or something that I monitor all PIDS without being limited to only a select few if I went with gagues.
Old Sep 28, 2008 | 04:51 AM
npccpartsman's Avatar
npccpartsman
You'll have to drill and tap one of the exhaust manifolds to get EGT temps. There's nothing in the PCM/ECM to read them, so the Banks won't matter there.
FWIW......you can get a LOT better electronics than the banks for a LOT less money.
Old Sep 28, 2008 | 08:38 AM
riggz's Avatar
riggz
Then go with the MSD DashHawk. It monitors everything that the OBD port will allow it. Oil temp, Trans temp, Boost, Coolant temp, Intake air temp, voltage, and a lot more. An add on EGT probe is also available. Total cost with the EGT probe puts you right at $400, which is a lot cheaper than it would cost you to get each of those individual gauges.
tuffnufly81
6.4L Power Stroke Diesel
Jan 7, 2013 05:05 PM
FICMrepair.com
Aug 3, 2011 02:46 PM
02GrayPowerStroke
19
Oct 17, 2007 03:43 AM
cwt580
Jan 1, 2006 06:24 PM
f350xlt460
Jul 30, 2003 06:05 PM
