Sponsored by: Auxito
Cruise Fires
Old Sep 27, 2008 | 06:12 PM
shorebird's Avatar
shorebird
Exclamation Cruise Fires
It appears that a number of people have yet to get the word that there is a fire hazard under the hood of a bunch of Ford trucks and cars. If you have one of the vehicles on this list; Ford: Parts Now Available to Fix Faulty Cruise Control and have not yet gotten the correct wiring harness installed (the first ones were improperly made) GET TO THE DEALER ASAP. BUT FIRST DISCONNECT THE WIRING TO THE CRUISE CONTROL STITCH ON THE MASTER CYLINDER. Another fire was reported yesterday.
Old Sep 27, 2008 | 08:55 PM
79 Trailer Special's Avatar
79 Trailer Special
Anyone know how to identify the upgraded harness? I just picked up an 03 F150 a few weeks ago and dont want it to have a bbq without me.
Old Sep 27, 2008 | 09:10 PM
svt4cobra6's Avatar
svt4cobra6
harness
I just picked up a 2000 f150 with the 5.4. Took it to the local ford dealer and they installed the new harness, took about 5 minutes. The harness just adds a fusable link so if there is a short there is no chance of the brake fluid catching on fire (which has happened). This is the circuit that connects to the switch that turns the cruise off when you push the brake. If you just have a wire with a single connector connection to the master cyclinder from the harness you do not have the upgrade. If you see a connector on both sides of the harness (one connecting to the brake cylinder and one connecting to the main harness), then you have the upgrade.
Old Sep 28, 2008 | 02:37 AM
ncranchero's Avatar
ncranchero
Old Sep 28, 2008 | 07:57 AM
kaboom10's Avatar
kaboom10
I put a weather-proof fuse holder in line on the power lead to the switch. I've got a 5 or 2.5 amp mini-fuse in the holder. If it pops I can see it instead of trying to chase down a fusable link. I've had no problems with it and the cruise works flawlessly.
Old Sep 29, 2008 | 05:40 AM
shorebird's Avatar
shorebird
The Ford fix is an in line fuse. It's just in a weatherproof case. See ncranchero's 2nd pic. The zip tie is holding it. It is not a fuse link.
Old Sep 29, 2008 | 06:42 AM
kaboom10's Avatar
kaboom10
Oh well. Same thing as the factory. From all the info I've gotten from reading other threads they led me to believe it wasn't a removeable fuse. I just don't like the stealership under my hood.
Old Sep 30, 2008 | 04:38 PM
79 Trailer Special
Thanks a bunch for the info and pics. It does not look like mine was done, guess its time for a fuse.
Old Sep 30, 2008 | 09:20 PM
svt4cobra6's Avatar
svt4cobra6
yep thought it was a fusable link as well. The dealership just did the installation while the truck was in the service entry line so it just took a minute, guess they are doing quite a few of them.
