High Idle on Cold Start
Old Sep 30, 2008 | 05:04 AM
ymeski56's Avatar
ymeski56
Der Postmeister
I have a couple of questions regarding the Cylinder output balance test! What does DTM & SFI stand for ? Also, does any of this mean that as in regards to this specific test, my 87' 5L, EFI truck is unfortunatly S.O.L.?
Old Sep 30, 2008 | 05:14 AM
subford's Avatar
subford
DTM: Diagnostic Test Mode.
SFI: Sequential Multiport Fuel Injection. A multiport fuel delivery system in which each injector is individually energized and timed relative to its cylinder intake event.
You do not have SFI and can not run an Cylinder output balance test.
Old Sep 30, 2008 | 10:03 PM
JoeM77's Avatar
JoeM77
Okay I ran the KOER test. Got the engine ID to flash four times. Pressed the brake, turned off the OD, then turned it back on. RPM's went up to about 1700 or so for about 30 seconds. After they came back down I got the single single CEL flash and stepped on the gas (not sure if I opened the throttle enough). After another 10 seconds or so, I got a code 33.
Not sure if I did it correct or not. I don't get home from work till late and the daylight is getting short in a hurry. I may try it again tomorrow night. If I don't get to it. I'll fiddle with it and repost on Saturday. Code 33 is EGR valve not opening but you mentioned only three digit codes...
Appreciate all the help
Old Oct 1, 2008 | 06:21 AM
subford's Avatar
subford
A 95 truck only has three digit codes.
If the spaces were long enough that could have a 111, 111 and that would have been the pass code.
Old Oct 1, 2008 | 10:51 AM
JoeM77's Avatar
JoeM77
Yeah that makes sense (doh) as I only got the 33 code once, which means that I got 111, 111. Okay. I will do the engine balance test this weekend.
Thanks,
Woodtroll
1983 - 2012 Ranger & B-Series
Dec 26, 2014 05:43 PM
jonathan9573
20
Mar 17, 2014 07:29 AM
mahd776
Feb 1, 2014 08:53 AM
~ChipsAhoy~
1997 - 2003 F150
Feb 17, 2011 03:19 PM
tcm368
29
Oct 30, 2007 02:54 PM
