manual air conditioning
Old Sep 25, 2008 | 09:39 PM
leeuzz's Avatar
leeuzz
Question manual air conditioning
I'm looking at buying the new ford truck. It has an option of a power group but you must choose manual air conditioning and its extra. Does the truck come with air or not? And if its manual why I am I going to pay extra for it?
Old Sep 26, 2008 | 12:50 AM
JDSTX's Avatar
JDSTX
I'll take a stab at answering....
I just bought a '08 STX and it sayz the same with it. I believe saying it's a 'manual' a/c means that it does not have a temp controlling thermostat is all.
Hope I'm rite.
Old Sep 26, 2008 | 09:53 AM
hhott71's Avatar
hhott71
If it arrives with AC delete, there is an AC kit available that uses Ford Parts, so its identical to ford installed ac.
Manual AC the better idea, vs the Automatic Climate Control.
Is it that tough to rotate a **** when you need to?
You're in a truck after all.
Old Sep 26, 2008 | 09:09 PM
JoSHN's Avatar
JoSHN
I've learned that with the automatic AC controls, you will actually be running your AC unit while also blowing out heat too.
It blows both to keep a consistent temperature.
So...basically the AC is constantly running.
In my eyes, it seems like a pointless feature. Unless you were really finicky about the temperature.
Old Sep 28, 2008 | 02:23 AM
johnh2000's Avatar
johnh2000
I like the manuel a/c better because you can better control the temp. I have found that with fords & others auto climate controls that there are situations where there is no perfect setting. The EATC on my wife's Montery minivan & a super duty I drove the other morning will give you no heat on 60 & too much heat on 65 on cool (60-70) mornings. With the temp. **** you can regulate the temp. better. All modern a/c systems run the a/c comp. on most settings for humiity control. You have the option to turn it off in most settings except full defrost which will always run the compressor unless the temp. is below or near freezing temps. for humity control. The a/c compressor affects gas mileage only a very small amout- ususally not even measureable or at the most 1 mpg & @ highway speeds there is less drag with the a/c on than opening the windows.
Old Sep 28, 2008 | 02:42 AM
JoSHN's Avatar
JoSHN
Actually... the AC affect the mileage a lot more than you think.
Mythbusters proved it.
Old Sep 29, 2008 | 12:02 PM
Wilber15's Avatar
Wilber15
It's an extra load on the engine. It's like towing a trailer, it's an extra load on the engine and it's going to drop your gas milage. When idling, the rpm's are raised when the compressor cycles on to compensate for the added load, which inturn ups your injector pulse width(more fuel).
Old Sep 29, 2008 | 04:21 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
just as they "proved" that it's more efficient to drive with your AC on than with windows down.
I think their results are atypical. My F-150 is more gas hungry with A/C...by at least 2mpg. So is my V-8 Durango, I can get 17 MPG city with a Hemi and no A/C. 12-13 City with A/C on.
They could have also done a more controlled test than just driving around a track until it ran out of gas with 2 different vehicles.
true 'dat
Old Sep 29, 2008 | 04:30 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
I think on a small 4-6 cylinder it will drop fuel mileage
but on the 5.4 seem to not matter
my 5 liter 302 1988 F150 you knew when air was on more fuel less power
just came back from a trip to Pittsburgh ran 70 MPH on cruse most of the time with air on full time got 21 miles Per gallon on trip real happy with my truck
its been giving me this type of performance all summer always run air don't like the wind noise
these are just my findings on my truck
Old Sep 29, 2008 | 04:36 PM
2004 xlt 5.4
Forgot to add running with air off mileage is same will not increase
Old Sep 29, 2008 | 07:48 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
lucky you. running with ac on with my 5.4 drops me into the sub 13 mpg city mark. I can squeeze 13-14 mpg with windows down and no ac
sucks though, because it's 85-92F 364.5 () days a year out here
Old Sep 29, 2008 | 08:20 PM
JoSHN's Avatar
JoSHN
Was that what they got as a result?
Man...It's been a long time since I watched that episode.
Instead...my common sense filled in the blanks.
It's smart like that sometimes.
ma115
Jun 4, 2014 09:50 PM
38 coupe
Jul 8, 2011 09:12 AM
katbird704
Jul 24, 2010 02:38 PM
ahicke
Feb 18, 2010 10:24 AM
prettieflowers
Jun 26, 2008 02:04 PM
