Axle wrap?!?
Old Sep 25, 2008 | 08:23 PM
X-70STANG-F150's Avatar
X-70STANG-F150
Axle wrap?!?
I got "temporarily detained" in some loose sand yesterday. As soon as the rear wheel(s) started spinning, the back end started jumping up and down like it was nuts . foward and reverse. Is this axle/spring wrap? I had this before the RAS too, that doesn't seem to make any difference.
Old Sep 25, 2008 | 08:37 PM
GregsSD's Avatar
GregsSD
Yes, that is axle wrap (or axle hop) and the best way to eliminate it is to get a good set of traction bars.
Old Sep 25, 2008 | 08:45 PM
X-70STANG-F150
Is that a sign of weakness in the springs or is it normal for the X?
Old Sep 25, 2008 | 08:46 PM
Monsta's Avatar
Monsta
Sit. Stay.
Depending on the hole it may be completely normal. I've seen tractors with NO suspension do the same!
As the wheel climbs up the side of the hole it loses traction and falls down only to bounce up when it gets traction again.
This is axle hop but could be due to the tire design as well as the particular hole you were stuck in.
Old Sep 25, 2008 | 10:01 PM
quietman's Avatar
quietman
Google "LandYot Radius Rods"
One of the terrific side-benefits of installing them
is that they eliminate axle-hop in deep sand, without
compromising ground clearance like traction bars do.
And of course T-bars do nothing as far as eliminating
wander/sway and vagueness/sloppy handling.
RR's fix a bunch things at once, shoulda been
original equipment.
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers, Auto
-zone aftermarket voltage gauge, LANDYOT Generation II Radius Rods, EBC green brake pads,
Custom 140 amp surge-proof low RPM alternator, matched Duralast 1K CCA batteries
Ford factory hood insulator, Mojave Pin-Striping
john
Old Sep 26, 2008 | 06:38 AM
MarkMoore's Avatar
MarkMoore
Another option is the RoadMaster Active Suspension
For the situation that you are describing, I would tend to agree with Monsta for the explanation.
Old Sep 26, 2008 | 08:34 AM
X-70STANG-F150
I've got RAS. This has also happened before the RAS and tire change. I guess what I'm wondering most is if it is normal for the EX's sissy springs or if mine are especially weak. I'm wondering if I need to add-a-leaf to supplement the RAS or change the whole rear spring pack...
Old Sep 26, 2008 | 05:24 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
2wd + loose sand doesn't always mix!
When I get my rear end a spinning...I simply engage my front!
I have an open rear differential and am more prone than a limited slip rear axle to getting stuck...but I've also got a 4x4.
I'm with Monsta...depending on the hole...that could have simply been your issue.
heck a fellow FTE'r that came to the Gatlinburg rally last summer was out on the OBX with is Ex (4x4) and got stuck even though he aired down his tires...thankfully another blue oval bro pulled him out!
So I'm not so sure any add on device would help you out in ALL situations...even 4x4...if the situation is just WRONG...you are stuck and you will likely get wheel hop until you are unstuck...just my thoughts...
Joe.
Old Sep 26, 2008 | 06:36 PM
MarkMoore's Avatar
MarkMoore
Originally Posted by X-70STANG-F150
I've got RAS. This has also happened before the RAS and tire change. ...
D@mn... I guess I sould have read your sig
I still think that Monsta has the right answer.
z 97ford1
1997 - 2003 F150
Oct 2, 2021 12:13 AM
seanjackmc
All Things Towing
31
Sep 18, 2019 09:23 PM
radmacks
Aug 1, 2016 11:01 PM
Craigwell
15
Jan 18, 2010 08:23 PM
Neal 97 250
Offroad & 4x4
Jan 15, 2010 09:27 PM
