Help!!
Old Sep 25, 2008 | 01:49 PM
cricket26's Avatar
cricket26
Question Help!!
Where is the PCV valve located on the 97 diesels???
Old Sep 25, 2008 | 01:54 PM
Neal 97 250's Avatar
Neal 97 250
There is no pcv valve on these. There is a CCV crankcase ventilation conection on the drivers side valve cover that is connected to the intake pipe.
Welcome to FTE!
Why do you ask? Are you having problems?
Old Sep 25, 2008 | 01:59 PM
cricket26's Avatar
cricket26
Question
my truck is having a smoking problem and I am trying to figure out why i have had many people say it is the motor messing up....any ideas on what to try??
Old Sep 25, 2008 | 02:32 PM
Neal 97 250
When and what color is the smoke. Smoke at startup or when you put a load on it. White smoke or black?
Old Sep 25, 2008 | 02:35 PM
cricket26's Avatar
cricket26
Question
the smoke is blue, it smokes on start up, idle, and at low speeds up until about 45 or so... smells like fuel to me. any ideas?
Old Sep 26, 2008 | 07:18 AM
Neal 97 250
Did you recently acquire this truck? It sounds like it has a chip or maybe some sort of 10k mod. You can look for a chip. Remove the emergency brake assembly (3 1/2" nuts) then remove the kickpanel. If you see a black rubber plug in the back of the aluminum boPCM) that sticks thru the firewall. You don't have a chip. If there is something plugged in there you do. Chipped trucks do smoke more and run better than stock trucks.
Old Sep 26, 2008 | 08:36 AM
Talyn's Avatar
Talyn
He could have a blown injector tip, or a bad injector O-Ring as well neal.
Shoudln't it smoke black if he's dumping all that fuel, not blue?
Old Sep 26, 2008 | 08:57 AM
Neal 97 250
That is true I am just trying to throw out ideas. And the chip is easier to find than removing VC's etc.
I am also trying to get some history.
If you can tell us all the info possible. How long you had truck, recent maintenance, modifications, air filter/oil changes, ebpv working or unhooked etc.
Just fishing here.
Old Sep 26, 2008 | 08:58 AM
c00nhunterjoe's Avatar
c00nhunterjoe
yup, shouldnt be blue, sounds liek you have something leaking down or a weak cylinder, a little more info on the truck would be a big help
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
