Sponsored by: Kumho
brake bore diameter
Old Sep 25, 2008 | 11:11 AM
someday's Avatar
someday
brake bore diameter
would a wheel cylinder with a 1 3/16" diameter be better than one with a 1 1/16" diameter or is it the other way around?
Old Sep 25, 2008 | 12:16 PM
Lazy K's Avatar
Lazy K
Depends what you mean by "better". For the same pressure from the master cylinder the bigger dia. cylinder will exert more force on the shoes. This means that the brakes will lock up with less pedal pressure. Also the bigger cylinder will need more fluid to move the pistons and hence more pedal travel. However with properly adjusted shoes this should not be an issue. Hope this helps.
Old Sep 25, 2008 | 12:33 PM
ynevada's Avatar
ynevada
for best results, replace it with, what you took off.
Old Sep 26, 2008 | 01:08 AM
someday's Avatar
someday
that is the problem i can not go by what is on there now...ive been able to cross reference and 1 3/16" should be stock...ill check when i take the old ones off
Old Sep 26, 2008 | 03:47 PM
aeomholt's Avatar
aeomholt
I have a -92 E350, 7.3 diesel, single rear wheel.
My bands are 12" by 3.5" wide and my wheelcylinders are 1 1/16" bore if this helps
BjornF16
All Things Towing
Sep 12, 2016 10:21 AM
brk300
Jul 15, 2016 12:51 PM
Notmeofficer
Mar 31, 2016 02:22 PM
Suprawill1
Escape & Escape Hybrid
Jan 23, 2014 12:32 PM
Fedman
Oct 18, 2011 10:54 AM
