Smoke?
Old Sep 24, 2008 | 05:10 PM
m0nkee221's Avatar
m0nkee221
Smoke?
I've had my PSD now for 4 months. Runs great, haven't had any issues (except the needle bearing killing my axle). Noticed about a week ago that it started smoking at start up. Never did it before. What is causing this? Should I be concerned? Thanks for the help.
Chad
Old Sep 24, 2008 | 05:12 PM
Smokin''s Avatar
Smokin'
Smokin
what color smoke are you seeing? Is the truck difficult to start at all?
Old Sep 24, 2008 | 05:16 PM
m0nkee221's Avatar
m0nkee221
No, it starts as usual. The smoke is white...maybe with a hint of blue.
bigsteve1969's Avatar
bigsteve1969
how cold is it when you start it?
Old Sep 24, 2008 | 05:18 PM
m0nkee221's Avatar
m0nkee221
70F roughly
Old Sep 24, 2008 | 05:20 PM
Smokin''s Avatar
Smokin'
Smokin
The smoke you are seeing is unburned fuel..
You may have a faulty GPR, or more than just a few bad glowplugs..just a few things to throw out there.
Old Sep 24, 2008 | 06:48 PM
m0nkee221's Avatar
m0nkee221
OK...and that would only cause it to smoke at start-up? It doesn't smoke any other time, just the first start of the day.
Old Sep 24, 2008 | 06:57 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Yes, because that's when it's coldest, and not fully burning the fuel.
Old Sep 25, 2008 | 03:09 PM
4inchlovin's Avatar
4inchlovin
A small amount of white smoke on start up is ok... But if it lasts more then a few sec.s you have a problem... Any chance of an SES light???
Old Sep 25, 2008 | 04:08 PM
m0nkee221's Avatar
m0nkee221
Nope, no light at all.
Old Sep 25, 2008 | 04:13 PM
Smokin''s Avatar
Smokin'
Smokin
I'd bet that since you aren't having any difficulty getting it started, you probably have a few bad glowplugs.
I've never had to change mine out, but this page may help:
Ford diesel 6.9 7.3 IDI
That site is directed as help for the old 7.3 IDI but it explains how to ohm or test light each glow plug to see which ones are malfunctioning.
Edit: another helpful page http://www.intellidog.com/dieselmann/tech.htm
Old Sep 25, 2008 | 05:02 PM
m0nkee221's Avatar
m0nkee221
Awesome! Thanks for all of the input!
