engine speed control kick out
Old Sep 25, 2008 | 09:48 AM
donewithsparkplugs's Avatar
donewithsparkplugs
I am tring to find anything here to help me with the axu engine speed control. The truck Is a 01 550 7.3 6spd box truck With lift gate. The truck has the drive shaft cut and run to a transfer box to run a pto in 4th at 2500rpms. The problem is that if you use the lift gate the rpm controler kicks out.
So I am tring the search to see what I find that might help. But if someone here were able to help me faster great.
Old Sep 25, 2008 | 09:54 AM
Kwikkordead's Avatar
Kwikkordead
Perhaps the PTO is loading the engine so much that the rpm drops farther/faster than the electronics want to see during use. So it turns off for safety reasons.
Kind of like the cruise control kicking off if the vehicle speed drops more than 10 mph when pulling a heavy load up a mountain pass.
Perhaps try it in third gear and see what happens.
Old Sep 25, 2008 | 10:04 AM
donewithsparkplugs
Ok but it is when you use the lift gate which is 12 volt. the pto makes 480 volts seperate of the trucks electrical system.and there is no change in engine speed when using the 480 just heavy 12 use. I hope to find wiring info or system logic.
Old Sep 25, 2008 | 11:46 AM
Kwikkordead
It might be easier to just run a 10 gauge wire to the lift gate.
Maybe even install a dedicated battery somewhere to buffer the load.
Old Sep 25, 2008 | 05:19 PM
donewithsparkplugs
well .02 volts drop and you get kicked out. New alt done.
Old Sep 25, 2008 | 05:31 PM
Kwikkordead
Well now you know that you have an early warning system for the alternator failing.
