Sponsored by: Real Truck
lost reverse
Old Sep 23, 2008 | 11:51 PM
2000+1998's Avatar
2000+1998
lost reverse
What to do? I lost reverse(it moves barely,with increased throttle).I had also lost first,but it came back.Fluid level is good.It shifts from first to fourth,fine.
I have no idea what happened.One time it worked OK,the next time Nadda.
It had a serious oil leak that covered the entire underneath of the truck.Could the oil have gotten into some of the transmission electronics?
Do I need a rebuild? I do pull a 33 ft 5er,14000# gross. trans temp usually around 180deg.
I'm at a loss. PLEASE HELP ! ! !
Old Sep 23, 2008 | 11:55 PM
riggz's Avatar
riggz
What truck?
What year?
What engine?
What tranny?
How many miles on it?
How often do you tow?
When you say it barely moves does the engine bog out or do the RPMs shoot up and you hear a whining noise?
Old Sep 24, 2008 | 12:29 AM
2000+1998's Avatar
2000+1998
more info
2000 f350 7.3 auto,100,084 mi. The only way to get the truck to move in reverse is to rev the engine fairly high and then it begins to move,but very slowly.It doesn't make any noise except for the engine. It is as if the truck has a very heavy load and it takes more rpm to make it move.
I do tow a 5er about 1/3 of the time.Total combined weight(truck,5er,load,etc) about 20000#.I weighed it after a long trip,loaded.
Thanks for the reply
yeah its mine
Nov 2, 2013 10:19 AM
036.0stroke
Nov 4, 2012 06:24 AM
just-n-time
13
Dec 2, 2009 06:34 PM
kiohio1985
Nov 10, 2006 05:51 PM
99 ranger bob
General Automotive Discussion
Jun 21, 2004 07:40 AM
