Fuel pump duty cycle?
Old Sep 23, 2008 | 08:59 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Just wondering, but when I hit the key, it says 100%. Start the truck 100% truck running 100%. Is that good? Just checking things with the reader and was curious.
Old Sep 23, 2008 | 09:05 PM
bkcowboss's Avatar
bkcowboss
Yes the fuel pump will stay 100% unless your truck is not running for 20 seconds I think then it should shut off. It is on or off, there is no in between. leave the key on for greater than 20 seconds (don't quote me on that) and you will see the cycle change to 0%
Old Sep 23, 2008 | 09:09 PM
gjgogel's Avatar
gjgogel
Yes that is perfectly normal. The pump is a constant output pump regulated by a mechanical regulator in the fuel filter bowl. If you left the key on without starting until the pump times out in about 20 seconds the duty cycle would read 0%. Otherwise it will always be at 100%.
Old Sep 23, 2008 | 10:12 PM
Powerstrokedlariat
Okay, that makes sense. I appreciate the info. Learning something everyday.
1956mike1956
Apr 18, 2023 09:53 AM
MattEturbo
Large Truck
Oct 15, 2016 03:08 PM
Elliott Tyler Yates
Mar 6, 2016 10:18 AM
bduemig
Aug 25, 2013 05:53 PM
ratzkid
24
Aug 12, 2011 04:52 PM
