Modular V10 (6.8l)
axle code???
Old Sep 23, 2008 | 06:51 PM
n8sv10's Avatar
n8sv10
axle code???
i have a 200o f250 v10 on the door sticker it has axle code with nothing under it and above it rc: 44 didnt see the 44 code on the threads with all the code breakdowns any ideas
Old Sep 23, 2008 | 07:24 PM
Monsta's Avatar
Monsta
Sit. Stay.
I'm finding a pattern with 2000 model years. There seems to be a number of them without axle codes.
You can always look on either one of the diff housings for the tag with the ratio.
Old Sep 23, 2008 | 07:30 PM
n8sv10's Avatar
n8sv10
yay guess ill just pull the cover and count then
Old Sep 23, 2008 | 07:50 PM
Heavy_Metal's Avatar
Heavy_Metal
Your front axle should have a tag bolted to the cover that has the axle code and the ratio.
Old Sep 23, 2008 | 08:09 PM
n8sv10's Avatar
n8sv10
thats about the only thing on the truck from factory not there i just got it 2 months ago with 160k and it still had the factory air filter in it just to give you and idea on the maintenance that was done, none, but the tag is gone im going to put new fluid in but wanted the ratio cause i think im going to do the 4.30 swap but wanted to see first
Old Sep 23, 2008 | 08:15 PM
Heavy_Metal
FYI: You don't have to count the teeth. When you get the cover off, spin the diff until you see the teeth count etched into the ring gear. It'll look like "42-12" or similar (different #s) just divide the first # by the 2nd.
Old Sep 24, 2008 | 05:07 PM
PartsPaul62's Avatar
PartsPaul62
Banned
According to the Ford Trailer Towing Guide I have access to, the standard axle ratio is 3.73. The 4.30 ratio was an option which bumped the gross combined weight rating from 17,000 to 20,000 lbs.
Old Sep 27, 2008 | 08:28 AM
wbulick76's Avatar
wbulick76
My 2000 is blank as well. I was able to find my ratio through the OASIS report under "as-built". (3.73, by the way)
Old Sep 27, 2008 | 10:22 AM
Ace!'s Avatar
Ace!
Or rotate the tires and count the number of times the driveshaft turns, or turn the driveshaft and count the number of times the tires rotate.
1979f_100
Sep 5, 2004 09:01 PM
FordMudder514
Bronco II
Aug 7, 2003 06:16 PM
JeffNSCR24
Oct 24, 2002 11:29 PM
Four Paws
Jun 19, 2002 09:52 PM
snoodick
Dec 26, 2000 09:22 AM
