FE PCV Hose
Old Oct 18, 2011 | 04:41 AM
  #31
The Masked Rider's Avatar
The Masked Rider
I ran into the same problem a while back and decided to make my own out of metal tubing. I used a pipe bender to form what I needed to run it to each end. For the larger end i slid a 3/4" long piece of metal tubing on the one I formed and soldered it. Can't remember the thinkness the piece I soldered (I played with a couple sizes) on and it doesn't matter if it fits on the tubing tight because its going to be soldered. Just needs to be the proper OD. Than just use rubber hose at each end. I even painted the metal tubing to match the motor so it looks factory. At least to the un-knowing.
Old Oct 20, 2011 | 08:39 AM
  #32
99hosss's Avatar
99hosss
Now thats the way you get things done
teamo
Jul 25, 2017 01:59 PM
FORD-or-Die
16
Jan 7, 2017 05:06 PM
NS70250
33
Aug 17, 2016 11:50 AM
Mr Hanky
Modular V10 (6.8l)
Nov 7, 2010 01:35 AM
jeffwhit
1997 - 2003 F150
Jun 17, 2009 03:58 PM
