General Automotive Discussion
The Impossible 2001 Ford Taurus Problem!!!
Old Sep 25, 2008 | 10:41 PM
Ford_Six's Avatar
Ford_Six
A distorted signal might not throw a code, and scoping the signals might not be a bad idea.
I haven't dealt with the protection system on Fords -per se- but have dealt with it and similar protection systems on Jaguars. Basically, the computer sees a change in rpm every time a cylinder fires, and when it doesn't see an expected change in rpm, it declares a misfire. This was a big problem on GM trucks years back- Going down a rough road would cause a similar fluctuation, and trip the check engine light. On newer vehicles, the emissions need to be kept in check, so they stop dumping fuel in on that cylinder.
FWIW, it's not the excess fuel that makes the cat run hot, it's the extremely lean condition caused by the slug of unburned air being dumped in.
johngeorge
2004 - 2008 F150
Dec 27, 2025 07:17 AM
danmm7
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
22
May 28, 2018 12:53 AM
rch10007
Modular V10 (6.8l)
Oct 1, 2014 05:42 PM
Kirk W
1983 - 2012 Ranger & B-Series
13
Oct 30, 2013 01:28 PM
fmjnax08
1997 - 2003 F150
Feb 2, 2011 07:31 PM
