Persistent PO172 Bank 1 too rich
Hello folks. Had quite a few error codes in the beginning... CATS o2 sensors etc.
B3000 3.0 2004
JUST REPLACED:
-PLUGS
-WIRES
-COILPACK
-Y PIPE AND ALL 3 CATS
-ALL 4 O2 SENORS
Issue:
ERROR CODE PO172, followed by mainly cylinder one misfire code. Other cylenders also randomly misfireing as well. Misfire in first 1000 revolutions code.
Issues only present when truck is at an idle. At any other time other than idle truck is running very well. Misfires are barely noticeable.
When truck is at operating temparature and turned off, its starts back up perfectly. But, if left sitting for 10-15 minutes it has to crank for a bit before it fires. BUT if allowed to cool, will fire up perfectly normal.
Stuck injector??
MAF sensor just cleaned an appears to be ok with live data readings of 4.20 at an idle and then gos up as RPM increases.
Newer engine, about 200 k on it<< newer lol
Smell of incomplete combustion at an idle.
All boots seem ok.
present codes:
bank 1 too rich
cyl 1 misfire
cyl 2 misfire
cyl 5 misfire
rdm misfire
misfire first 1000 revoloutions
ONLY AT AN IDLE i can clear the codes and drive as long as |I want. But as soon as I stop..... engine light
Any help would be appreciated. No cash for a dealer repair
B3000 3.0 2004
JUST REPLACED:
-PLUGS
-WIRES
-COILPACK
-ALL 4 O2 SENORS
Issue:
Stuck injector??
All boots seem ok.
present codes:
bank 1 too rich
cyl 1 misfire
cyl 2 misfire
cyl 5 misfire
rdm misfire
only paid 100 bucks for it tho. no huge hopes. lol
Getting a compression tester soon at crappy tire.... ugh another 40 bucks.
Kirk
A few threads down I have a similar issue, with the exception that my code is P0174. I had thrown part after part at it to try and figure it out to no avail (egr valve, TPS, IAC, hoses, etc.)! Finally just yesterday I took it to the stealership and they determined that it was MAF related. So hopefully you too will find a more economical situation.
Hey guys, thanks for your replys. Pawpaw: my reader doesnt have that ability. Sorry didnt answer right away, been busy with work.
I thought too it could be MAF related. But my reader live data says its measuring air. whats the airflow specs for this engine supposed to be? Anone know by chance??
mines reading 4-6 gpm at an idle and goes up as rmp increases. I hope its a |MAS issue. Not putting new heads on this truck. Man, just had this engine installed t=not too lang ago... 50,000 k ago.
Injector resistance should be between 12 & 16 ohms & all injectors resistance reading should be closely matched.
hey boys. did a compression test today.
looks like cyl 1,2,3 are good @ 120 lbs
4,5,6 however are not. 60 - 90 pounds.
this is now beyond my understanding and there are just too many possibilities- time to get the ol girl into a shop and get er fixed
you guys rock man and thanks for your help.
Kirk
Kirk
AU_ADF150
2009 - 2014 F150
12-03-2017 01:10 PM
Rexman
07-19-2005 06:35 PM
