New here, need help w/ engine
Old Sep 22, 2008 | 10:29 PM
azskycop's Avatar
azskycop
Want to say Hello as I have never posted here before but have found this site useful and fixed things....THANKS.
I have a problem, and have searched, but have not found an answer. I have an 03 Expedition with the 5.4 Triton V8. It has about 110,000 miles and 10K ago I replaced all the plugs and coils. Today it started hesitating under partial acceleration, no engine light, no other problems or indications. Full throttle accelerates smoothly. Idle is pretty smooth but seems to have a slight "burble". I was thinking fuel filter or maybe injector problem....where should I start and how hard will it be to fix?
I can do most fairly easy stuff myself but if it gets real involved I need a good (and cheap...or at least reasonable) mechanic in the Tucson, AZ area if anyone knows one.
Thanks for the help!!
Old Sep 22, 2008 | 10:56 PM
alloro's Avatar
alloro
Could be the IAC valve or the MAF sensor getting dirty, or like you said an injector acting up. I'd clean the first two and throw some injector cleaner in the tank, then see what happens.
Old Sep 23, 2008 | 07:07 AM
azskycop's Avatar
azskycop
Thank you for the quick reply. Not being a mechanic I don't know what the IAC valve is and only have a vauge idea of the MAF sensor. Is there any easy instructions on here somewhere that would show me where these are located and how to remove and clean them?
Old Sep 23, 2008 | 08:24 AM
kailor's Avatar
kailor
Have you had the transmission fluid flushed or changed lately?
Old Sep 23, 2008 | 08:57 AM
alloro's Avatar
alloro
The Idle Air Control (IAC) valve is on the top back of the throttle body. It has a 2-wire plug going to it and two 7mm or 8mm bolts holding it on. It's a tight squeeze, but you can get in there and get it off.
The Mass Air Flow (MAF) sensor is in the housing right after the air filter. You have to disconnect the ductwork from the MAF and spray a cleaner inside the hole you see when looking through where the air flows.
Brittany Madl
1997 - 2003 F150
Jan 20, 2017 02:56 PM
bstarz40
Dec 14, 2016 05:30 PM
Pro DIY
53
Sep 18, 2015 02:04 PM
Tennesseepowerstroke
Escape & Escape Hybrid
59
Sep 15, 2011 09:37 AM
1990fordbronc
1978 - 1996 Big Bronco
Apr 4, 2006 09:54 AM
