Big "puff", now barely runs...HELP!
Old Sep 22, 2008 | 11:30 AM
Expansivebandvan's Avatar
Expansivebandvan
Exclamation Big "puff", now barely runs...HELP!
Does anyone have any guesses to what I'm looking at here? I started my Expy today (5.4l) and when I put it in gear and hit the gas I heard a LOUD pop/poof and then lost all power.
Now the truck starts but just barely, and has the puffing/huffing sound while it's trying to run. I can't see anything visibly wrong. No plugs popped out, no leaks from the heads, the exhaust seems intact.
I'm not sure where to start, Cat collapsed? Head gasket (although the coolant is full and no leaks), Timing belt/chain?
The truck has 105k on the odometer and ran great up until this morning! Also the check engine light did not come on...somehow!?!?
HELP!
Old Sep 22, 2008 | 12:45 PM
alloro's Avatar
alloro
What you could've heard was a muffled backfire in the throttle body. Your fuel pump could've went and now you're not getting the correct amount of fuel. First thing to do is connect a pressure gauge to the fuel rail and see what the fuel pressure is.
Old Sep 22, 2008 | 01:02 PM
Expansivebandvan
Thank you, are there any symptoms leading up to it that would indicate a fuel pump going bad?
Old Sep 22, 2008 | 01:16 PM
projectSHO89's Avatar
projectSHO89
I'd be checking closer for a blown spark plug....
Old Sep 22, 2008 | 02:25 PM
Expansivebandvan
-Fuel pressure is right at 30 and jump up to 40.
-Checked again for blown plug with absolutely no signs
It definitely sounds like a muffled backfire. Any other suggestions?
Old Sep 22, 2008 | 02:45 PM
alloro's Avatar
alloro
A large vacuum leak, crankshaft position sensor, camshaft position sensor or timing chain.
Old Sep 22, 2008 | 03:30 PM
saberworks's Avatar
saberworks
I had pieces of my cat in my Jeep break loose and clog the outlet. Wouldn't run right after that, virtually no power. Easy to check on the jeep as the joints were clamped not welded. Not sure about Expedition.
Old Sep 22, 2008 | 05:48 PM
Expansivebandvan
f/k it...it's off to the shop.....Thanks!
Old Jan 11, 2009 | 12:05 PM
CanadaBob's Avatar
CanadaBob
Same thing happened to me yesterday
Did you end up fixing the problem (what was it?) and how much did it run you?
Thanks
P.s. 199 Expedition Eddie Bauer 132,000kms
