i hate air cond!!!
Old Sep 21, 2008 | 08:53 PM
miottimouse's Avatar
miottimouse
Red face i hate air cond!!!
good day any one have a soulution to this problem? i am trying to get at the dist bolt to set the timeing on a 460 with the stock air compresser and tried about every thing short of removing the pump/brackets cant get in with a wrench standard or swivel end,socket 1/2" or 1/4" drive with universal joint as it seems the only place to get bite is on the pump side any help?regurds joe
Old Sep 21, 2008 | 08:59 PM
twisted_axel's Avatar
twisted_axel
I hate to say it but I bought the crooked wrench to adjust mine I hate buying tools that only serve one purpuse, but it was easier than trying to get to that darn bolt Good luck I bought mine at Orielies Auto Parts it was like 15 Bucks
Old Sep 21, 2008 | 10:57 PM
1985 Ford F-150's Avatar
1985 Ford F-150
Naw make one your self just heat it up with a torch till its good and red then just bend away in a vise.
Old Sep 22, 2008 | 12:23 AM
1985 Ford F-150
And its free if ya have an extra wrench or two and a torch.
Old Sep 22, 2008 | 09:45 AM
fmc400's Avatar
fmc400
MSEE
Everyone is right...you either have to buy the crooked distributor wrench or make one of your own.
Old Sep 22, 2008 | 09:54 AM
75F350's Avatar
75F350
Right tool for the right job.
I love buying tools. I especially like the specialty tools. Such a drool factor when you can complete a job that takes a guy without the correct tool, in a matter of minutes while he is struggling to get creative.
The correct wrench will have a box end to limit rounded bolt, and it will be much longer than a homemade wrench that is all bent up.
I use Snap-on tools, so putting the heat to these is something I am not willing to do. I will spend the extra dough on the right tool. Sure does make it easy as pie.
No busted knuckle either. That is worth it weight in gold right there.
Old Sep 22, 2008 | 12:50 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I agree, either way will do the job. Personally, i would make my own. But whatever floats your boat. Go to a pawn shop or something, pick up a chinese wrench for a buck, and bend away.
Old Sep 22, 2008 | 01:35 PM
Blue Bomber's Avatar
Blue Bomber
i like Harbor Freight for "one use" tools. they are really cheap, and when they break i know i didnt spend that much on 'em. ive had Harbor Freight tools last a good bit when i dont put my whole weight on them.
Old Sep 22, 2008 | 09:43 PM
miottimouse
got the answer! decided to put my other 468 motor in as this one has a wicked rear main seal leaking any ways and the other one is all ready set up to go good thing i didnt charge the air cond as i have to remove any ways and i will bet a $1.00 the dist is seized tight upon working a few hours to loosen the manifold studs i see the moter mount rubbers are completly shot so i will have to pull the motor to get at them any ways thanks for the help
ps air is still a pain to work around regurds joe
Old Sep 23, 2008 | 12:35 AM
Alvin in AZ's Avatar
Alvin in AZ
Same here. :)
I bought mine already bent at the swap meet for extra cheap since it
was already "ruined" and all. ;)
1/2" on one end and 7/16" on the other end that something like a fat
screwdriver will slip through for extra leverage.
On my 360FE with factory A/C... I used 1/2" knuckle-socket for years
but ran across the modified boxed-end and couldn't resist buying it. :)
YMMV
Alvin in AZ
