I have 2001 ranger 4x4 4.0 sohc,my 4x4 is not working i have put a new transfer case motor on and it still doesnt work,all fuses are good,are there any relays under the hood,when i turn the **** t 4 high i hear 2 clicks from the control module behing the passenger kick panel i took that off and it looks ok,i also have taken the gem located to the left of the radio off and it looks good,but sometimes it would go into 4 wheel drive and sometimes it wont,also when you switch it to 4 wheel drive the motor turns a little and them it goes back to 2 wheel it doesnt turn enough to lock it in,like it wants to go into 4 wheel and something is telling it not to.someone please help.
I have power to the shift motor because you can hear it move alittle but it does not move enough to lock it in,it acts like it going to lock then the motor stops and goes back the other way.
When i switch it to 4 wheel drive i don't even get a light on the dash,would vaccum still be the prblem ,also does a 2001 have vaccum hubs and if yes were would i look.
There are no PVH hubs on a 2001. Front axle is constantly turning...just have to lock in the transfer case to apply power to them.....one nice reason the 4x4s don't get that good of gas mileage
