where does this go?
Old Sep 21, 2008 | 02:36 PM
custom_nirvana's Avatar
custom_nirvana
where does this go?
the red wire with a nut on it, that is sticking straight up and ends at the boost tube.
i took my dads spyder out to find a leak and when putting everything back in place i ran across this wire and i know i didnt take it off of anything, but where does it go?
thankx
Old Sep 21, 2008 | 02:56 PM
Delvac1's Avatar
Delvac1
I think it goes to the IAH. Intake Air Heater. just to the left of the center of the spyder. There is a little bolt sticking that's where it goes. Someone else that knows for sure will chime in.
Old Sep 21, 2008 | 03:00 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Trace it backwards to see if it goes to one of those relays there on the right side of the fuel filter.
Old Sep 21, 2008 | 03:05 PM
custom_nirvana
ya it goes to a relay.
Old Sep 21, 2008 | 03:11 PM
custom_nirvana
goes on this?
Old Sep 21, 2008 | 03:28 PM
tjbeggs's Avatar
tjbeggs
yes it goes on the intake heater you have circled.
Old Sep 21, 2008 | 03:31 PM
custom_nirvana
put it on last? or does it matter?
Old Sep 21, 2008 | 03:42 PM
4inchlovin's Avatar
4inchlovin
heres a usefull pic for those of you that don't have it...
Old Sep 21, 2008 | 03:45 PM
custom_nirvana
great pic, but i dont even see the wire im having a problem finding where its goes.
i dont remeber ever taking it off, maybe my dad disconnected it and dont need it? since its not in ur pic?
Old Sep 21, 2008 | 04:45 PM
twags6's Avatar
twags6
Nolan removed his and plugged the hole for the boost line. The AIH would be right below the word "fitting" where the brass fitting connects to the clear tube. Its not needed for the engine to run, but you might not be able to run certain tests like the cylinder contrubtion test with it unhooked.
If you dont hook it up, make sure that wires removed or at least wrapped up with tape so it doesnt short out.
Old Sep 21, 2008 | 07:32 PM
4inchlovin's Avatar
4inchlovin
LOL i wish my motor was that clean!!! I stole that pic from someone els if i could remember who i would tell yall so you could throw some reps... I think it was brandon (Bdrummonds) Mark (Markadeck) or Dan (Kwikkordead) if not one of them i apologies...
Old Sep 22, 2008 | 09:16 AM
custom_nirvana
Thankx for the help guys, im from the 94 to 97 forums and my y-pipe is much simpler.
68bumpside
40
Apr 18, 2015 03:25 PM
cr500monster
Oct 19, 2014 06:49 PM
shillinghillf600
Nov 23, 2010 07:39 PM
Dutch123
1978 - 1996 Big Bronco
Oct 28, 2007 08:18 PM
blackout150
Jul 28, 2007 03:17 PM
