Strange new electrical problem
Old Sep 20, 2008 | 05:53 PM
ferret2's Avatar
ferret2
This morning I went out to move the X and she barely cranked fast enough to fire. I let it fast idle for a few minutes to charge the batteries. When I shut it down and started to step out I got the ding-ding like I left the lights on - only no lights on. I checked for a current draw with it off and when I initially touch the probes of the meter I get a spike of 1.5A, rapidy dropping off to 0.006A so nothing I would call a short or draw. I'm sure the clock takes that amount of current. Now I have been having what appears to be alternator problems in the preceeding weeks - I get a flicker of the idiot light when the rpms get above 2000. Someone said it sounds like a diode.
Any ideas?
Thanks
Craig
Old Sep 20, 2008 | 06:35 PM
ReAX's Avatar
ReAX
The alt problem sounds like the rectifier diodes are failing. You either need to replace the rectifier or the alt. I've seen rectifiers available on line, but you will need to figure out what alt you have, I think it's a 3g, but I am not sure.
Put the truck on a charger, let your batt or batts charge up fully and try again.
Old Sep 20, 2008 | 07:25 PM
1's Avatar
I priced the rectifiers instead of a whoel alternator at a couple popular auto oparts stores and the price difference was only a few dollars between a whole new alternator, and just the electronic part. Do yourself a favor and dont buy a cheapy parts store rebuild unless you feel like replacing them every couple months for teh rest fo the life of the truck lol.
Old Sep 20, 2008 | 10:30 PM
ferret2's Avatar
ferret2
I'll try the charger but when I checked the voltage I was getting 12.3V on both - a little low but considering how low they were and I only ran the truck a few minutes at high idle i didn't think they were the cause of the dinger. I checked the batteries seperately with the cable off.
Thanks
helomech
Dec 17, 2016 09:43 PM
93nighthawk
Aerostar
Jun 19, 2009 03:10 PM
Yougotthehit
Mar 7, 2009 05:25 PM
jericho41sc
Escape & Escape Hybrid
Jun 9, 2006 09:50 PM
t_mckenzie
May 6, 2003 11:33 PM
