PCM code po603?
Old Sep 20, 2008 | 04:01 PM
midnight1967's Avatar
midnight1967
PCM code po603?
Hi everyone i dont talk on her alot but i had a question about code po603. i have a diablo sport programmer and i usually run it with the 65 hp econo tune and there are no codes trown but today i put in the 85 hp tune and wemt a couple of miles , got into it a little bit and now its saying that code po603 POWERTRAIN CONTROL MODULE KEEP ALIVE MEMORY (KAM) ERROR, does this mean the pcm is bad?
Old Sep 20, 2008 | 04:08 PM
PaysonPSD's Avatar
PaysonPSD
Not to worry. Typical code when using a programmer. Your PCM is fine. For more info about P0603 just type 0603 in the Search This Forum box at top of threads list.
Old Sep 20, 2008 | 05:36 PM
ron's power stroke's Avatar
ron's power stroke
in case this is the first time you have seen this code...it also caused by un hooking the batteries for a while.....like Robin said..not to worry..
Old Sep 20, 2008 | 05:59 PM
midnight1967
thanks alot that makes me feel a whole lot better .thanks again
Old Sep 20, 2008 | 08:30 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
I have the diablo as well and anytime you change tunes it will show this code for awhile. Just clr it with the diablo and your good to go. Or dont clear it, it doesn't matter at all. Oh, and it's not just the diablo, I believe anytime you use a chip/programmer and change anything this shows up. Totally normal!
Old Sep 20, 2008 | 09:41 PM
white Buffalo's Avatar
white Buffalo
When I had the Daiblosport Predator Programmer it did the same thing. Chips won't have the code but either way it doesn't matter - you are good to go.
Old Sep 20, 2008 | 10:18 PM
midnight1967
hey thanks alot was nervous seeing the code but im good now. thanks for the help.
PAVEMENTMAN
Dec 12, 2007 08:40 AM
purplewg
Dec 5, 2007 06:27 PM
jsrdaily
May 31, 2007 09:00 AM
case2273
Jul 17, 2006 06:40 AM
famf23
Feb 26, 2005 06:32 PM
