Sponsored by: Real Truck
f350 codes
Old Sep 20, 2008 | 04:46 AM
terryswafford's Avatar
terryswafford
f350 codes
Today my check engine light came on.I stoped at advance auto. They told me it was a bad c02 sensor location bank 2. The exaust also smells very bad.The guy at advance auto said before I start replacing sensors get it checked out at a shop because it could be something else. Anyone have any suggestions or coments? Also if it is the 02 sensor where is bank 2 located? Is it a easy changr or something that needs to go to the dealer for
Thanks for any help
Terry Swafford
2000 F350 SD
4x4
long bead
52000 miles
Old Sep 20, 2008 | 12:22 PM
ReAX's Avatar
ReAX
To do O2 sensors, I like this special socket from Lisle, it cost about $8 and is cheaper/easier than making your own. It is just a socket with a slit for the harness to come through, I find it easier to use and an open/box end wrench. The procedure I use is to spray it with penetrating oil and let it sit at least 15 minutes. Then let the motor run until the pipe is warm to the touch. Then unscrew it.
The o2 sensors are scheduled to be changed around 60k. I would advocate just doing both while your under the truck.
Old Sep 20, 2008 | 05:35 PM
shorebird's Avatar
shorebird
I guess that if the person at Advance Auto told you that it was the bank 2 O2 sensor they read the code, yes? If they did, just what code, did the system show? A "P" code for the bank 2 O2 sensor can be any of a number from P0150 to P0167. Each of those 18 codes being a different problem. As for the "bad smell" the source of it may be the reason that the sensor has failed. If something has gotten into the combustion pathway via the air intake or the fuel and passed into the exhaust system it may have contaminated the sensor. I recently saw a forum thread about changing the O2 sensors on a '97 5.4L over at "How-To" - O2 Sensor Install - F150online Forums
O2 sockets are available through the tool loan program at my local Advance Auto store. It is a do-it-yourself job especially if you have a set of ramps. These are what I have; ( Advance Auto Part Number: 11905) I feel a lot safer when under a vehicle that is sitting on them, rather than on a set of stands.
Old Sep 21, 2008 | 02:24 PM
terryswafford
does anyone know where the bank 2 sensor is located? Also how many 02 sensors are on this truck??
Thanks
Old Sep 21, 2008 | 04:13 PM
projectSHO89's Avatar
projectSHO89
Get and post the exact fault code.
Steve
Old Sep 21, 2008 | 05:10 PM
ReAX's Avatar
ReAX
It's on the same side as the farthest rear cylinder.
Old Sep 22, 2008 | 07:27 PM
terryswafford
The code at advance auto was P0171 system too lean bank 1
Old Sep 26, 2008 | 02:17 AM
terryswafford
I posted the exact code. any one have any experience with this.I'm just trying to find out as much as possible so I don't spend a lot of unnecessary money...
Thanks to all
Terry Swafford
Old Sep 26, 2008 | 07:05 AM
projectSHO89
Most likely, you have a vacuum leak and the sensor is only reporting the conditions it is seeing.
Steve
jorge995
1997 - 2003 F150
Jul 21, 2013 04:03 PM
MikeRizz
Mar 24, 2010 09:56 AM
tuckpete
Apr 14, 2009 07:20 PM
AnOldDog
Modular V8 (4.6L, 5.4L)
Apr 6, 2007 08:54 PM
deekon
3.8 & 4.2L V6
Dec 29, 2005 10:51 AM
