Sponsored by: Auxito
m12 or m14 wheels?
Old Sep 19, 2008 | 10:37 PM
stephen.osborne1's Avatar
stephen.osborne1
m12 or m14 wheels?
I have a '00 f-150 4x4 w/ 4 wheel ABS. I am hearing some noise from the front end and am thinking one of my front hub bearings are going out. I've been pricing parts and I need to know if I have m12 or m14 wheels. How do I tell? Hopefully I won't have to replace the hub for a while, but I need to have a heads up just in case.
Old Sep 19, 2008 | 10:47 PM
galaxie641's Avatar
galaxie641
WEll I am guessing that refers to the 12mm or 14mm studs. I would say you have 14mm BUT the change took place some time around '00. The rim itself may have a stamp on it that says 12 or 14 and of course if you have a micrometer you can just measure them.
Old Sep 19, 2008 | 10:51 PM
mstngmikegt's Avatar
mstngmikegt
Simple way is take a lugnut off and take it to a major auto parts store that sells them. Most will have a small display with various studs on them that you can try your lugnut on or if they don't they should be able to get you a wheel stud off the shelf in either size for you to try. If you have aftermarket wheels and lugnuts, the lugnuts should be stamped with the size in most cases.
Old Sep 20, 2008 | 10:45 AM
2002 F350V10's Avatar
2002 F350V10
11/27/99 is the swapover build date for ford. Prior are 12mm later are 14mm.
Old Sep 20, 2008 | 04:06 PM
Bobby82490's Avatar
Bobby82490
12mm studs use a 19mm socket on the lugnuts.
14mm studs use a 21mm socket on the lugnuts.
Gage2502
Feb 2, 2017 03:30 PM
Ste14mi
Oct 24, 2013 08:15 AM
Piolet
Apr 8, 2013 12:17 AM
gordo2
Offroad & 4x4
15
Mar 29, 2010 10:09 AM
JaysRanger
Offroad & 4x4
Apr 13, 2009 08:08 PM
