adjusting rear brakes
Old Sep 19, 2008 | 04:41 PM
brian931's Avatar
brian931
I'm thinking my excessive abs activity may be a result of my rears not adjusted enough. What is the adjustment procedure??
Oh yah 99 4X4,
Thanks
Old Sep 19, 2008 | 05:22 PM
Rockledge's Avatar
Rockledge
What do you mean by excessive ABS activity?
Old Sep 19, 2008 | 05:26 PM
brian931's Avatar
brian931
When I slow down almost to a stop my abs kicks in, I have had both sensors replaced in the front within the last 2yrs and I just replaced the vss so I thought maybe the rears might not be pulling thier weight while braking causing the abs to kick in.
Old Sep 19, 2008 | 05:41 PM
Ben Marshall's Avatar
Ben Marshall
Jack up the rear end, put transmission in neutral. (Make sure you block the front wheels, so it doesnt roll away) On the inside of the backing plate near the bottom, there should be an oval shaped rubber plug, pull it out. Using a brake adjuster, or a screwdriver will work if you dont have an adjuster, turn the adjusting screw until the shoes start to drag on the drum. (spin the tire as you are adjusting, and you will hear the shoes make contact) Turn the screw a few more times, until the tire stops. Stick a small screwdriver into the slot and push the adjusting lever (the little lever that holds the adjusting screw from backing off) away from the teeth and hold it there. Turn the adjusting screw backwards about 10-12 notches, until you can turn the tire again. Make sure you keep track of how many times you turn it, as you will want to adjust the other side the same amount. Then repeat for the other side.
Old Sep 19, 2008 | 05:51 PM
Rockledge's Avatar
Rockledge
Rear drum brakes are supposed to be auto-adjusting, but as Ben noted they can also be manually adjusted by removing the rubber plug from the backing plate and turning the adjusting screw star wheel.
Here's something else to consider regarding unwarranted ABS activity: https://www.ford-trucks.com/forums/6...bs-advice.html
Old Sep 19, 2008 | 08:25 PM
brian931's Avatar
brian931
On this topic is there an easy way to disable the ABS circuit so I can use the truck safely until I get it fixed?? I tried the fuse but that killed the spedo too! I tried pulling the relay but that appeared to do absolutely nothing??
Old Sep 20, 2008 | 10:30 AM
Ben Marshall
Does it have 4 wheel antilocks, or just rear wheel abs? also, is your abs light on?
Old Sep 20, 2008 | 01:49 PM
GozInSnowz's Avatar
GozInSnowz
Just unplug one of the front ABS sensors. That will prevent ABS from kicking in..
Old Sep 20, 2008 | 07:15 PM
michigan66's Avatar
michigan66
The lazy man's way of adjusting the rear breaks is to beck up briskly and then apply the brakes. This activates the self adjusters. Do this several times and your brakes should be adjusted. Also, after you do this you shouldn't have to depress the brake pedal as much to apply the brakes.
Old Sep 22, 2008 | 11:33 AM
brian931's Avatar
brian931
So I tried to adjust the bakes as was mentioned with no luck, so I pulled off the drums and everthing was siezed tight, also there was a broken spring on the one side and there was no way the self adusters were working so I'm hoping that when I get them rebuilt my issue will go away. I'll let you know.
Thanks
Old Sep 22, 2008 | 06:28 PM
GozInSnowz's Avatar
GozInSnowz
Ah-ha! I knew it..
Glad you found the cause (hopefully).
