94 Mass air ?
Old Sep 19, 2008 | 01:16 PM
GlennFordx4's Avatar
GlennFordx4
94 Mass air ?
I found a 1994 f-150 xlt in the junk yard that I have been able to get a lot of parts off of and I noticed that it has a mass air 5.0 in it,I thought mass air didn't start until 1995 and the build date is 8/93. The truck was a clean one until it got hit in the front. I wanted to get the block to replace my 5.0 efi in my 86 what if anything should or could I get off of it to help me change over to mass air. The computer is there but it has the electronic od trans and mine is aod,so that won't work,I want to get the rear too but don't know if my drive shaft will fit the yoke as the new rear has a vss in it. Can anybody here tell me if what I want to do will work
Old Sep 19, 2008 | 04:07 PM
EPNCSU2006's Avatar
EPNCSU2006
Mass air F150s were hit or miss in 94 and 95, with all F150s being mass air with OBD-II in 96. If you are going mass air, grab as much of the wiring as you can. It is a good bit different than the 86 wiring, but you should be able to steal what you need (sequential injector harness is the biggest) from the 94 harness and add it into the 86 engine wiring harness. The automatic mass air computer will run the engine without the electronic transmission being present, so it would probably be wise to grab the computer too while you have the chance.
Old Sep 20, 2008 | 06:58 AM
GlennFordx4
I will see the owner of the junk yard on Monday and get a price,I hadn't planed on switching to mass air but I will as long as I can get everything on the cheap end I might as well do it and then I will have a better choice in cam shafts.I was still under the impression that I would need a computer from a manual truck or a c6 to make it work right.
Anybody know if the rear with vss will work in a truck without.
Old Sep 20, 2008 | 08:01 AM
subford's Avatar
subford
It should work OK, the companion flange may need to be changed to fit your "U" joints if yours is different.
Do not worry about the vss in the top, just leave the sensor in there to plug the hole with no wires attached.
It is more than likely a 3.31:1 ratio 8.8 rear end.
What do you have now?
Old Sep 20, 2008 | 08:09 AM
subford's Avatar
subford
The 94 PCM computer will turn on the CEL and have codes about the transmission but it will run the engine.
Also the 94 PCM is a CCD computer so make sure you get the Black ICM off the fender also as they changed in 94 from the old "push start" to the "CCD" Ignition system.
Old Sep 20, 2008 | 09:12 AM
GlennFordx4
The rear in my truck now is a 3:08 open and I am going to get a 3:55 or 3:73 limited slip for a little better take off from the red lights
Old Sep 20, 2008 | 09:28 AM
subford's Avatar
subford
Check the tag on the rear end out of this truck or the door info, as I said it maybe a 3.31:1 ratio rear end in that 94 truck.
Old Sep 20, 2008 | 10:35 AM
GlennFordx4
Yes I know what to look for and I am thinking it will be a 3:55 just hope it is a LS rear thanks.
Old Sep 20, 2008 | 11:01 AM
jk89cat's Avatar
jk89cat
well lets talk about this a little bit, 1st noone has metioned that mass air in a 94 fseries was a california emmsions vehicle, so being in nj i can see why it would be there, it wasnt hit or miss, cars in that era were differnt as if it had to have the cali emmsions std it was either dis, or mass air, tbird/cougars are another liek that. the trucks and vans as well. . more than likely if that truck has a electronic overdrive it will have a 3.55. i would persoanlly go witt a 3.73 as its alot more fun and moves the truck a whole lot easier
Old Sep 20, 2008 | 11:56 AM
GlennFordx4
I forgot that Cali got the mass air first that must be what it is,and it does have the e4od trans thats why I figured it would have 3:55's in it also,for the price I can get it for I will take the 3:55 rear with the limited slip and at the very least I can do a gear swap later I just want to find out if it fits the stock driveshaft in the 86.My 86 uses a two piece shaft maybe the back half of the 94 would work if mine doesn't fit or at least my yoke might be able to be used on the 94 rear.
Old Sep 20, 2008 | 11:57 AM
subford's Avatar
subford
In 94 & 95 all 5.0 trucks everywhere had MASS air.
The hit or miss in 94 and 95 was the 5.8 and yes only California had the 5.8 with MASS air.
Old Sep 20, 2008 | 12:34 PM
GlennFordx4
I bet he finds the rear end is a 3.31:1 as most of them with this set up in 94 & 95 had this rear end.
First off I have never saw a ford pick up with a 3:31 rear no matter of the year and most standard rear that came with a E40D electronic tran was a 3:55 and a 3:73 as a option,and as far as mass air 95 & 96 were standard no matter if it was a 5.0 or 5.8 and California had them a year or two before.I simply forgot that California got them first and to find one in a NJ junk yard is odd,I think I am going to try and get the whole truck and strip every thing I can use and give them the cab,bed and frame back to scrap.
Old Sep 20, 2008 | 12:56 PM
jk89cat's Avatar
jk89cat
thats not true, my now passed on freinds 94 5.0 f150 5 spd was a speed density truck, and nj got cali emmision std vehicles because of thier emssion laws.
Old Sep 20, 2008 | 01:00 PM
subford's Avatar
subford
Then you have not looked much, I have two trucks and a van with the 3.31:1.
I did not know what transmission this truck had when I wrote that, the ones with 3.31:1 all had the 4R70W transmissions.
Not true.
In 95 only the California 5.8 had Mass Air. The 5.0 had Mass air in 94 & 95 in all states.
That is why the truck in NJ has Mass air because all 94 trucks with the 5.0 had it that year.
Old Sep 20, 2008 | 02:16 PM
GlennFordx4
Well after searching I do see that they have a 3:31 gear replacement but when I look in catalogs they only show 3:55 thru 4:11 as being the norm.
