Offroad & 4x4
Speedometer Error
Old Mar 31, 2002 | 06:50 AM
karljay's Avatar
karljay
Speedometer Error
Old May 24, 2002 | 07:54 AM
showtime946's Avatar
showtime946
Post Speedometer Error
Have a 1978 F150 with a 460, 9 inch lift and running 35 inch tires. The speedometer reads about 10 MPH slow with these over size tires (actual speed is 10 MPH faster than speedometer reading). What do I need to do to correct the speedometer error?
Old May 24, 2002 | 10:25 AM
trixie's Avatar
trixie
Speedometer Error
[updated:LAST EDITED ON 24-May-02 AT 11:29 AM (EST)]You need a different speedometer drive gear in your transfer case. A speedometer shop (if you have one in your area) or a good transmission shop should be able to figure out which gear you need (how many teeth) and hook you up with it no problem. Or you can put in lower gears front & rear (which is the costly but better solution if you plan on wheeling with big tires). Or you can just live with it...you'll learn to ignore it eventually
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
