Sponsored by: Real Truck
2002 F250 bolt patterns
Old Sep 17, 2008 | 08:53 PM
jas504on's Avatar
jas504on
Hey guys,
I am looking to put some new wheels on my 2002 F250. I am looking at these stock rims off of the 2008 F250. To my understanding the bot pattern is the same but the lug size is different? Is this right? If so what will I have to do to make these fit? I think the 2008 is 14x1.5 and the 99-02 is 14x2. What size addapters will I need?
Thanks
Jason
02 F250 7.3
Old Sep 17, 2008 | 09:09 PM
ReAX's Avatar
ReAX
McGard shows 2003-2008 as M14x1.5 and 98-02 as M14x2.0. It looks like your right, I wouldn't have suspected a difference.
The good news is the 1.5 and 2.0 are thread pitch. The diameter of the lug is 14mm, so the hole in the wheels are the same size, it's just the tooth spacing in the nuts that will be different. So no adapters needed.
Old Sep 17, 2008 | 09:26 PM
jas504on's Avatar
jas504on
bolt pattern
thanks that's great news. But another thing I heard was that they would sit further inside the wheel well or something and maybe rub by shortening your turning radious. Is this what the addapters are for? What r they for?
Thanks,
Jason
Old Sep 17, 2008 | 10:09 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You're thinking spacers to move the wheel out I think, normally run on the back of duallys looking to fit in wider tires
Old Sep 17, 2008 | 10:19 PM
PowerStrokeHD's Avatar
PowerStrokeHD
The bolt pattern is the same and as ReAX pointed out, the only difference is the thread pitch...
'98 - '02 uses 14mm x 2.00
'03 - present uses 14mm x 1.50
The reason people use wheel spacers (not adapters) is to compensate for the difference in backspacing which changed in '05. Many people including myself do not recommend wheel spacers for safety and wear and tear concerns, but some people are ok with it and it does correct the problem of the '05-up wheels sitting too far inboard and rubbing on the pre-'05 trucks.
If you do decide to run wheel spacers, just make sure that they are quality and hub centric to hub centric in design. FYI... A good quality set is going to run you around $600. Check out the following link, many of the guys here are running Fred's spacers...
Wheeladapter.com Wheel Adapter Wheel Spacer Used Wheels New Rims Tires Gage Guage Gauge Wheal Wheals Adaptor wheelspacer wheelspacers stud studs billet bolt pattern custom parts part titanium fabrication aluminum rims rim part parts titanium coating
If you can live with 18" wheels, here are a couple of direct bolt on wheels that will work perfectly for your truck...
These first ones say they are for a 4X2, but they fit 4X4's just the same and are a steal at the price for a proper hub centric wheel...
SVT F250 4x2 Truck Polished
Here are factory 18" '04 Harley wheels at a very reasonable price...
SVT F250 2004 Harley Polished
Sean's 97 F250
Aug 6, 2024 07:11 AM
Cole333
May 19, 2017 08:22 AM
adamsquared
Jun 13, 2014 09:54 PM
460MAGNUM
13
Jul 30, 2010 05:37 PM
DS02F250
Dec 18, 2004 06:29 PM
