Last I checked, that seller had a quantity availabel of like 24. So now it might be a little lower with a couple of you guys buying them. But its a steal, even if you dont need them.
On the bag, they said ZD10. Is there a difference between ZD10 and ZD11? It is a Beru part with the name on it. What is the difference between ZD10 and ZD11
I thought the ZD-10's were for the 6.0L... but somewhere inside the famous "for a penny" thread, I believe the correct application for the ZD-10's is called out by someone. Just have to read through to find the reference, and I don't have the time right now or I'd do it for you.
EDIT: Did a quick web search, and it seems that the ZD-10's BECAME the ZD-11's. More searching indicates that the ZD-10 number was originally used in reference to the 94-97 7.3L engines, but was later confirmed (by several people) that they fit the models all the way up through 2003 as well. Ford changed the model number for some reason, but none of my research indicated a problem with running the ZD-10's in the newer body style models.
