e4od trans
Old Sep 16, 2008 | 09:42 PM
scbronco's Avatar
scbronco
Unhappy e4od trans
hey everyone
i have a 95 f250 7.3 diesel 4wd
my trans has been acting up
driving around my trans will randomly rev up and not engage in gear.
it happens if i keep a steady speed around a turn or town and the step on the gas. the truck will rev up till about 3 grand then bang into gear. after a wihle of this the OD light flashes and it goes into limp mode. the truck will sound as if it were stick and shift slugishly.
i had it flushed and the e pack replaced. when this isnt happening the trans shifts perfect.
after i shut it down and cycle through it will go away
torque converter?
help
Old Sep 16, 2008 | 10:09 PM
spazinweasel's Avatar
spazinweasel
if it goes away after cycling i would think it was the comp. you can have a tranny shop scan it some even do it for free. just hope its not rebuild time.(big $$)
Old Sep 16, 2008 | 10:57 PM
Gobstopper909's Avatar
Gobstopper909
im thinking your tc is slipping. heat will tear into it. how did the trans fluid look when it was flushed? should start slipping when trans is hot. also it depends on what scanner you have. my superchip didnt throw a code on the slipping..just when the od light came on
Old Sep 17, 2008 | 07:34 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I can't see how it could be the torque converter.
The best way to find out what's wrong is to have the codes read. Those will give you a place to start to diagnose what's wrong.
Old Sep 18, 2008 | 04:01 PM
Gobstopper909
I cant say that im an expert in any words, but when my tc was slipping, the syptoms matched scbronco. Good Luck!
Old Sep 18, 2008 | 04:23 PM
scbronco's Avatar
scbronco
gobstopper what were your symptoms when you figured that u needed a torque converter
Old Sep 19, 2008 | 04:28 PM
Gobstopper909
i would be driving in od and i would accel a little bit and the truck would rev up but not catch. only did it when trans was warmed up. so i would just take it easy on it. after 10 minuted of driving, the od light would start to blink. I had serviced my trans 10k mi before so i know the fluid wasnt bad. brought it to the trans shop and he said tc took a dump.
Old Sep 19, 2008 | 05:43 PM
scbronco's Avatar
scbronco
yeah and then it goes into like limp mode and all the shifts are jumpy right?
Craver17111
Jun 24, 2016 10:00 PM
Greg5OH
101
Nov 2, 2012 03:55 PM
Lobo
Jul 24, 2008 08:07 PM
rowekmr
Dec 26, 2007 01:55 PM
1972 Ford Thunderbird 429 V8
Oct 6, 2002 11:23 AM
