E4od
Old Sep 16, 2008 | 02:13 PM
Cdy1's Avatar
Cdy1
E4od
ok i have a 95' bronco with a 351/E4OD, every once in a while it will **** hard 1st-4th or it will shift WAY to early and the OD OFF light flashes, if i turn the OD off while its doing this it will shift just fine, when i bought it it had an after market remote start, i dont want to get into the mess of wires but i think it may have somthing to do with it, any ideas?
Old Sep 16, 2008 | 02:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You need to read the codes. Without knowing the codes all anyone can do is guess. The codes will tell you where to start.
Old Sep 16, 2008 | 02:23 PM
Cdy1's Avatar
Cdy1
iv already had it on 4 different ones that give nothing
Old Sep 16, 2008 | 08:17 PM
jk080's Avatar
jk080
Transmission Rebuilder
If the OD light flashed, it has a code.
Take it somewhere that uses scanners everyday to fix cars, they should be able to get them.
