TT v's 5TH Wheel
Old Sep 15, 2008 | 03:38 PM
redfire42's Avatar
redfire42
Question TT v's 5TH Wheel
My wife and I were at the "Largest RV show" this past weekend in Hershey PA. We would really like to get a 5th wheel and say good bye to the TT. I know some people who had bad luck with TT's like a roll over. Some guys like the TT because of the use of bed space. I was always told a 5TH wheel tows so much better then a TT. I am not sure I like the way my TT tows, maybe I need new shocks? But anyways We saw some sweet 5TH wheels that we were interested in one being the Sandpiper. Hitch weight was 2100 and dry weight was 10,800. Now is that to much for a 3/4 ton? My TT hitch is only 850 with a gross of 9600. We also like the Wildcats. They wern't near as heavy as the Sandpiper. OH and it has to have bunks.
Whats every ones thought between a TT or a 5er and the weights I mentioned and or what would be a safe hitch/pin weight and tow weight for a 3/4 ton.
I ask here because I have no means to ask anywhere else. Thanks guys
Old Sep 15, 2008 | 03:44 PM
nlemerise's Avatar
nlemerise
Can you pull it? Sure can. I wouldn't pull it with less than a 1-ton dually. I've pulled numerous TT's and 5'ers and the 5'ers are much better overall IMO. The difference between a TT and a 5'er is as great a difference as pulling a TT or 5'er with a dually over a SRW. A dually with a 5'er will feel like you are running on a set of rails...rock solid!
Old Sep 15, 2008 | 03:47 PM
totin_tools's Avatar
totin_tools
I have a TT and love it, but I also pull with a dually. Doesnt sway like everyone says and I have pulled it all over from coast to coast. I think my next move will be to a motorhome. Just skip the 5th wheel and go big. Weight wise I would think you should be ok, but I dont know for sure. My TT and truck wieghs 23k lbs.
Old Sep 15, 2008 | 03:48 PM
Ponyboychris's Avatar
Ponyboychris
5'vers tow more stable than TT's in my opinion. Easy to hitch up especially if you have a v-tailgate. Yes, you lose bed space, but you can find ways to get around it. I tow a small 5'ver and I never will go back to a TT.
Old Sep 15, 2008 | 03:55 PM
ron's power stroke's Avatar
ron's power stroke
with a 5er the hitch wieght is balanced out over all 4 corners of your truck..a TT put all the wieght right on the very end of you truck...the 5er will not feel no where near as heavy on your truck as the TT even thow it weights more..
Old Sep 15, 2008 | 03:58 PM
redfire42's Avatar
redfire42
I don't mind loosing bed space, its fire wood taritory anyways. I just don't know of going over the 1500 pound range for the hitch weight plus fire wood.
Old Sep 15, 2008 | 03:59 PM
redfire42's Avatar
redfire42
A TT with the weight distrabution is suppost to do the same thing I thought?
Old Sep 15, 2008 | 04:06 PM
ron's power stroke
TT is at the end of the bumper...it lifts weight off of the front end and puts it on the rear...my brothers 5er weights just under 15,000LB M/T...my over loads just start to touch when i hook onto it and my truck sits level....it takes 1500LB to make the over loads touch..
Old Sep 15, 2008 | 04:09 PM
Ponyboychris
That's a nice looking rig, Ron.
Old Sep 15, 2008 | 04:12 PM
ron's power stroke
thanks Cris...that 5er belongs to my brother..it does everything..when it rains the roof vents will close..when it gets hot the AC kicks on..when it gets cold the furnace kicks on...how do you call that camping lol...
Old Sep 15, 2008 | 04:13 PM
redfire42's Avatar
redfire42
We found a used Fleetwood Wilderness an 04 29BHS and dry weight is 8730 with a gross of 11450. That cann't make the hitch more the 1400 since dealer doen't know. Air bags would help also I guess.
I like your pictures Ron!
Old Sep 15, 2008 | 04:15 PM
redfire42's Avatar
redfire42
Does it come with its own maid?
Old Sep 15, 2008 | 04:16 PM
totin_tools
Better shut them bay doors before you leave Ron.
Old Sep 15, 2008 | 04:17 PM
ron's power stroke
thanks...my hitch is a 16,000lb...i wouldnt worry about air bags right off..
Old Sep 15, 2008 | 04:18 PM
ron's power stroke
lol my sister in law....
we did forget one...it was flappin in the wind for a few miles....
the only time i new that camper was back there is when it hit the pot hole a couple seconds after i did..i pulled her at 65MPH in OD in 80E on a side road....didnt get a chance to hit the big road..
