Remove ignition switch
Old Sep 15, 2008 | 12:39 PM
ssj7kids's Avatar
ssj7kids
I did a search and found out how to remove all the switches etc from the dash except the ignition switch.
Am I correct that it is held on by the bezzel? Looks like two little slots that I could make a tool for to unscrew?
Don't want to bugger it up. So I thought I would ask the experts.
Thanks in advance.
Old Sep 15, 2008 | 01:06 PM
jaye's Avatar
jaye
Don't know if its the same as a 55 but on the 55 I used a small flat screwdriver just push in and turn. It has a spring behind that provies the pressure to hold the bezel on.
Old Sep 15, 2008 | 07:39 PM
Julies Cool F1's Avatar
Julies Cool F1
HI Guys,
Disconnect you negative battery lead if it's hooked up, then reach behind the dash, push the ignition switch toward the dash from behind, against the spring pressure, and twist it until it is released from the bezel.
J!
Old Sep 15, 2008 | 09:23 PM
ssj7kids's Avatar
ssj7kids
Julie and Jaye,
Thanks, I'll give it a try tomorrow. I did notice that it would move forward if I pushed it from behind.
The cab is sitting on a dolly so there's no battery anywhere in sight ... LOL
Thanks for your help.
Old Sep 15, 2008 | 10:10 PM
Julies Cool F1
HI SS,
I might not have phrased things right above. The ignition switch should have a cut in its threads that align/lock with a stud on the dash hole to keep it from turning. When you push on the back of the switch, turn the BEZEL!
tjman
Oct 16, 2009 08:03 AM
66 twin i
Sep 16, 2009 10:20 AM
63beater
Apr 18, 2009 08:19 AM
samahi72
Apr 23, 2008 12:59 PM
jethro1
Apr 8, 2004 06:30 AM
