Sponsored by: Real Truck
removing an abs module????
Old Sep 16, 2008 | 09:38 PM
wwest's Avatar
wwest
Have you checked the motor mounts.
I have had instances in the past where trying to accelerate in speed while going up a slight incline the transmission would "judder" in and out of the proper downshift gear ratio.
It turned out that loose motor mounts was the problem.
Old Sep 16, 2008 | 09:47 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sorry, I mean "F-series Superduty" when I say Superduty.
Old Sep 17, 2008 | 06:46 AM
dodgefreak8's Avatar
dodgefreak8
tranny is rebuilt with about 50 thousand on it
Old Sep 20, 2008 | 11:21 PM
dodgefreak8
2 more questions can I use the psom out of a 99 f350 with a v10 in it?? also can I remove the psom from the gauges and install it in my gauge cluster? My set of gauges is nicer with more gauges and digital odometer.
fancyketchup
Feb 20, 2015 10:15 AM
SuperMike
Jan 25, 2012 06:10 PM
mikeb 51
Oct 16, 2011 03:26 PM
Bowie
20
Aug 12, 2009 07:22 PM
