Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
changes to my project plans
Old Sep 14, 2008 | 08:03 PM
Snowking's Avatar
Snowking
So refining some of my plans.
The 1951 Mercury M6 cab and fenders are going to be Mickey Moused onto the 1993 International school bus that currently has a 7.3 IDI diesel. A custom classic styled car hauler will be build long enough to carry 2 1/2 ton trucks approx 35 feet of deck needed.
Since the 7.3 motor was supposed to go in my 1967 that project is obviously is capute. So I am going to take my old 1975 halfton that runs great but looks like hell. And exchanged bodies so I'll have a 1967 with power disc brakes, power steering etc. The 390 in my 1975 will recieve the racing camshaft/ and external rebuilding new carb, distrubutor etc.
So what do you figure???? Oh almost forgot to mention I'm planning on a full flip hood and fairly high cab using airbag cab mounts like a older style semi tractor.
Old Sep 14, 2008 | 08:12 PM
Corner Gas's Avatar
Corner Gas
I like the fender idea and the motor swap makes sense to me.
Old Sep 14, 2008 | 10:28 PM
Dustin1690's Avatar
Dustin1690
Sounds like some good changes none the less....
Old Sep 15, 2008 | 07:22 AM
96sherm's Avatar
96sherm
i like the mickey mouse idea. never seen a school bus with big ears before
Old Sep 15, 2008 | 02:39 PM
preppypyro's Avatar
preppypyro
Ryan i think thats a great idea. Plus if you ever wanted too, you could work the truck on teh side and make a few bucks doing flatdeck work.
Old Sep 15, 2008 | 04:42 PM
Snowking's Avatar
Snowking
I just figured the bus frame and axles are way too good to scrap. The bus is the truck equivalent of a tank. every brake has 2 or 3 brake lines going to it brand new brakes and shocks was obviously upkept to high gonvernment standards it can do 100kph fairly eaisly. I'm just a little curious what the GVW is cause I want to build a fairly heavy deck/shielding and also want to be able to haul 2 Ford/ Mercury trucks at one time.
Old Sep 15, 2008 | 04:44 PM
Dustin1690's Avatar
Dustin1690
Sounds like a good plan to haul your Ford/Mercury trucks
Old Sep 15, 2008 | 05:47 PM
preppypyro's Avatar
preppypyro
Hmm the gvw should be on there somewhere should it not? Then it would be easy to figure out from there.
Old Sep 15, 2008 | 08:55 PM
Fomoko1's Avatar
Fomoko1
Keep us posted.
Old Sep 16, 2008 | 09:48 AM
preppypyro's Avatar
preppypyro
I forgot Ryan, what year is that bus? I could probably find the gvw for ya, if theres no stamp or anything on there.
Old Sep 18, 2008 | 10:14 PM
Snowking's Avatar
Snowking
The bus is a 1993 it has 8.25 rubber I think or maybe it's 9.00 it one of the 2 I forget.
Old Sep 18, 2008 | 10:23 PM
preppypyro's Avatar
preppypyro
When it comes to the weight that the tires can hold thats easy.
I assumed you meant you werent sure what the gvw of the vehicle though was, right?
Old Sep 18, 2008 | 10:37 PM
Snowking's Avatar
Snowking
Ya I just wasn't sure how much a bus can lug, but 2 1/2tons can't weigh that much?
Old Sep 18, 2008 | 10:57 PM
preppypyro's Avatar
preppypyro
No it shouldnt be too bad, like just think what a bus full of adults would be? Im sure they must be safetly rated to haul adults and have the seats full.
Old Sep 18, 2008 | 11:00 PM
Snowking's Avatar
Snowking
cause what a 1/2 ton weigh 5000 so prob 2 trucks and the deck would be 13000 most likely?
