denzo high torque starter
Old Sep 14, 2008 | 06:47 PM
7.3mule's Avatar
7.3mule
does anybody have install pics for this starter? i can only seem to get one of the bolt holes to line up.......help!!!
Old Sep 14, 2008 | 07:10 PM
lhud's Avatar
lhud
Mule,
You didn't say which year your truck is.
Mine is an '02 and I installed that Denzo, 13 teeth, high torque starter from D&B Electrical.
This starter is set up for either the 2-bolt or 3-bolt pattern. With the 2-bolt pattern, the first (easy access) bolt is near the ground side at approx. 7:00 o'clock position. The second bolt is basically opposite to the first bolt - this one is sort of blind. You should be able to get your hand up there and make up the bolt. The solenoid, etc. should be located on the top if the orientation is correct.
The forward end of the starter barely clears some other equipment by approx. 3/8", but was no problem.
I didn't take any pics since it was a very easy intall.
Good luck,
knapikmichael
Jun 5, 2007 06:13 AM
PAUL_2
Jul 4, 2006 04:19 PM
jimdandy
Electrical Systems/Wiring
Mar 4, 2006 08:17 PM
toolebox1
Nov 9, 2005 11:51 AM
TOUGHLover
1983 - 2012 Ranger & B-Series
Dec 5, 2002 06:13 PM
