starter troubles
Old Jun 5, 2007 | 05:37 AM
knapikmichael's Avatar
knapikmichael
starter troubles
starter stayin engaged on start ups and the starter tested good at auto zone any suggestions
Old Jun 5, 2007 | 06:13 AM
PLC7.3's Avatar
PLC7.3
Bad starter relay on the fender maybe.........ignition switch problems. Try removing the small wire on the relay..... put a test light on the wire to ground......turn the ignition switch as per normal start......release...... does the light stay on after the key is released. Other test.. turn key to on, jumper the 2 large terminals on the fender relay (use old screw driver or jumper cable) does engine start...does starter disengage immediately when jumper power removed. May need a friend it this is a standard trans..
PAUL_2
Jul 4, 2006 04:19 PM
jimdandy
Electrical Systems/Wiring
Mar 4, 2006 08:17 PM
toolebox1
Nov 9, 2005 11:51 AM
TOUGHLover
1983 - 2012 Ranger & B-Series
Dec 5, 2002 06:13 PM
deleontow
Feb 22, 2000 03:38 PM
