Typical Problems from what I hear
Old Sep 14, 2008 | 01:55 PM
tm0231009's Avatar
tm0231009
The manufactured date on the Explorer is 6/01. It was sent in to get aligned. Mechanic said that it needed a left rear wheel bearing before he could align it. I went to O'reilly's and got the wheel bearing and was going to do it myself. Now I can't get the rotor off or the knuckle off. I can't get the upper ball joint and the tie rod joint off the knuckle I tried using pickle forks and pry bars and pb blaster and just can't get it. Please help me out guys, thanks.
Old Sep 14, 2008 | 07:51 PM
steve(ill)'s Avatar
steve(ill)
the bearing is out and you heard nothing??? also the bearing is a sealed unit pressed into the rear knuckle. your on the right track, but getting the knuckle off the car is teh EASY part. you need a press to get the bearing off and install new. ball joint and tie rod and normal stuff, sometimes they can be tight. more beating and the pickel fork normally works.
