1997 Explorer Lowbeam Headlights
Old Sep 14, 2008 | 08:41 PM
Texas162001's Avatar
Texas162001
Unhappy 1997 Explorer Lowbeam Headlights
I have a 97 AWD 5.0 v8 explorer, the headlights started off with just the driverside headlight did not work, but then my Dad "fixed it temporaroly" to get it passed inspection not sure exactly what he did but it worked for about a month then all of my lowbeam lights went out including fog lights both my high beams still work. we have changed to headlight on/offswith, High/low switch. the message center in the console says my low beam light are working just fine. Please help.
Old Sep 14, 2008 | 09:47 PM
firepop5's Avatar
firepop5
There is a "lamp out module" that controls headlight messages in message center. Current passes through it on the way to the headlights. Google "explorer lamp out module". If it is faulty, the headlights won't work. The module is in the console beneath the message center. You can take it out and open up to see if some of the soldered conntacts have broken. If so, you might be able to resolder them. If not, replace module about $70 from ford.
rangerbait
6.7L Power Stroke Diesel
Feb 13, 2016 06:03 PM
Larry Wall
May 19, 2015 10:09 PM
mudslinging79
1978 - 1996 Big Bronco
May 7, 2015 09:46 PM
20Mike
Mar 11, 2015 02:04 PM
martinraz
Aug 12, 2014 05:32 PM
