Problem with charging system-NEED HELP!
Old Oct 10, 2008 | 12:21 PM
Alvin in AZ's Avatar
Alvin in AZ
Cool, thanks for the update. :)
Glad you got it going and at least know what it is.
I won't be having that problem anytime soon tho. ;)
I replaced all those "push on" connections with eyelets, years ago. ;)
My pickup don't look like much but I've fixed many things on it and
before they broke even. ;)
It's called "maintenance". :)
The opposite of...
"if it ain't broke, don't fix it"
YMMV?
Alvin in AZ
Old Oct 10, 2008 | 10:07 PM
luckytrucker's Avatar
luckytrucker
should you have this problem again, connect a multimeter to the battery and check the voltage. if it is not above 13 volts remove the plug from the voltage regulator with the engine running. look at the plastic plug and you will see four letters on it A, S, F, and I... connect a jumper wire from the A terminal to the F terminal and see if the voltage on the meter starts to rise. if it does, unplug the jumper wire before it gets too high because it will just keep going up and up until it burns out the alternator. if it does rise up you're looking at a problem with the regulator itself, if it does not check the alternator and the wiring
just my $0.02
-Jason
Old Mar 14, 2010 | 11:40 AM
feed trkr's Avatar
feed trkr
alt. lite stays on but charges?
I am working on an old POS 79 F-150 that's been in the family since new enough history. The alt. lite stays on while running but has 14+ vlt charge. I've found no loose wire or connections under the hood and about to go into the dash. My memory has failed as to how the lite functions in the system. Myself it doesn't matter if the lite goes out as long as it charges,but my nephew thinks it's a concern.
Handdsaw
Jan 26, 2017 08:25 AM
Micksdog
Jan 29, 2016 06:18 PM
handyandy123
Jun 6, 2014 08:17 PM
Pitcrw6
Aug 26, 2012 12:59 PM
rwtdct
Aug 7, 2012 08:05 PM
