Bad Vibes
Old Sep 13, 2008 | 03:57 PM
raerjim's Avatar
raerjim
Bad Vibes
I wqs off work yesterday, and crawling around under the 55, looking for the possible cause of a bad vibration I get between 60-70 mph. Shaking the drive shaft ,I discovered that the front u-joint had apprx. 1/16th" side to side play (latteraly) as if the cross were 1/16th too small "side to side". Went to my local parts house for a replacement, with the shaft, to find that the front joint is asymetrical, (wider than it is tall) where the rear one is not. They did not have the joint in question, but made one up for me out of 2. Took it home, installed both joints, test drive, WOOHOOO!!! Problem solved! It was a good day off. Bill Number Dummy- Is that common? Different style u-joints on the same shaft?? The counter man said he thought the rear one was a chevy part #..
Old Sep 13, 2008 | 04:05 PM
Fomoko1's Avatar
Fomoko1
While fairly rare it`s not totally uncommon, I`ve occasionally seen wider a taller then wide u-joint but usually both are the same style/size u-joints on a drive shaft.
Is your drive shaft stock?
Old Sep 13, 2008 | 04:22 PM
raerjim's Avatar
raerjim
No Morris, it's been shortened and welded.
Tailgate55
Jan 16, 2014 07:02 PM
FrontRangeF150
Apr 3, 2007 05:20 PM
Gnikhog
May 26, 2006 03:09 PM
dragonryder79
Jun 30, 2003 08:18 AM
