Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Need good hand cleaner
Old Sep 17, 2008 | 08:38 AM
wizzard351's Avatar
wizzard351
ill get the nastty greasy stuff off with wd-40 then finish off with fast orange
Old Sep 18, 2008 | 01:09 AM
Chaosracing's Avatar
Chaosracing
Fast orange first then dawn dishwashing soap.
Old Sep 19, 2008 | 11:23 PM
mikeyswood's Avatar
mikeyswood
Originally Posted by stryder
I use powder Tide laundry detergent. Its cheap and works great! It provides plenty of grit to scrub grease. Works best with warm water as cold will leave a bit of a slimy film until it drys.
^ that slimey feeling is the fast from your hand being emulsified from the caustic agent in Tide
As for me...a good 60 grit will get rid of the junk
Old Sep 21, 2008 | 08:07 PM
Aftrmidnite's Avatar
Aftrmidnite
Wypalls by Kimberly Clark, they are waterless hand wipes, "towelets" come 50 or 100 in a pop up canister. You can get them from a HVACR supply house. They fell like they have grit in them, but there is no loose grit. Also are great for cleaning up tools when you are done. Also use 6 or 8 mill Nitrile gloves from Graigers. If you let the grease and solvents repeatedly soak into your hands you may get skin cancer later down the road.
Old Sep 24, 2008 | 10:18 PM
gruberoliver's Avatar
gruberoliver
A good nail brush...powdered Borax (with a little Ajax if needed)...soap up with just a little water and scrub. Powdered Tide works well...just put a little hand lotion on afterwards.
Old Sep 26, 2008 | 09:50 AM
ghunt's Avatar
ghunt
I found Permatex hand cleaner the other day, it's a lot like Gojo & Goop, but it seems to work very well. I use that, and then Lava soap later.
Fast Orange is pretty good too except that it leaves grit all over your hands that you need to wash off.
I may have to try picking up some Boraxo.
Old Sep 27, 2008 | 01:14 PM
mwvdub's Avatar
mwvdub
I use Kresto hand soap. It is made from walnut shell powder and is the best stuff I have used.
Old Sep 28, 2008 | 09:27 AM
monckywrench's Avatar
monckywrench
I use miscellaneous laundry detergent, dish soap, and hand cleaner along with a bucket of water. Immersing my hands in the bucket works better than running water over them because the strong soap solution has more time to work.
When the bucket gets too nasty to use, I empty it on fire ant mounds. The soap ensures they never come back to that spot.
Old Oct 3, 2008 | 03:01 PM
Alcan's Avatar
Alcan
I use Dawn dish washing soap and gojo mixed. Seems to work pretty well.
Old Oct 4, 2008 | 08:29 PM
Dstosh's Avatar
Dstosh
WOD2025ACSA, Hand Cleaner, Water Activated (case of four 84 oz. bottles). That is the price for a case of four. It is the best hand cleaner I have used. Doesnt wash away when you add some water to it mid-cleaning.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
