TC replacement
Here's the deal;
Why did I replace the TC ?, I had a rattle, very noticable at idle, Hated that extra noise and was worried what would happen if whatever was loose broke,
I know several guys have had the rattle and have run a lot of miles that way-I would rather fix now than wait for a break down that took out the tranny as well.
Which TC did I get ?, I thought about a stock but It seems the stock TC may be the weakest link in the powertrain so why, I wanted something better . Looked at the Suncoast etc., bulletproof but pricey and really meant for a new built tranny (like BTS), I'd rather get what matches my Excursion-stock tranny, 80E & 4" ex. The top TC's are great but more than what matched up with the rest of the truck.
I ended up with a Daaco ex HD, has a billet housing, multi disk clutch and a slightly lower stall (100 to 200 rpm). Meant to handle a bit extra torque and heavy towing. The billet housing do look a lot stronger. Were the stock had the mounting studs welded on spacers that held the TC abou 3/16ths away from the flexplate the billet has the studs mounted directly the face of the housing- the flexplate sits flush with the housing meaning the billet housing is about 3/16ths thicker. There may be more machined away inside for the multi disk clutch but I could tell that new TC weighed more than the stock.
Cost me $450 + tax.
How's it work?, Seems pretty nice, locks up tight, I can notice the lower stall, feels more the way it should be. It tightened up the feel of the TC/tranny.
One interesting result- I had on takeoff from stop a slight bump or lag-kind of like a real quick downshift, enough to notice but barely before the replacement. That is completely gone. I guess the old TC was a little loose inside. I'm glad I changed the TC out. Now I'll have to put some mileage on to see how it holds up
Other notes, I ended up removing my exhaust downpipe. My repair manuals didn't show this as a needed step but there was no way I could see to get to the top passenger side housing to eng bolt. piece of cake after pulling the exhaust. I also left the tranny and transfer case together as a unit when I pulled them out. They balanced on a floor jack pretty well.
I was glad my Son in Law was around to help with the Exhaust and pulling/reinstalling the tranny.
Jerry
What do you guys think?
aldridgec- The combo tranny/xfr balanced pretty well side to side (I left the crossmember attached just in case) but it was front heavy, we muscled it with a jackstand lifting and setting it down a notch at a time, another good floorjack at the front of the tranny would have made it fairly easy.
harleydude03- I mispelled the correct is dacco they are a nationwide tranny parts supplier www.daccoinc.com I think they have over 200 locations. I got mine in Alb,NM
jwhitetail & zack7.3- I hope it helps the MPG's-I'll check as the miles go by
strokin_it7.3- Thanks, pardon me for asking, tell me about the goodies, I tend to be blind to the obvious.
Jerry
