Offroad & 4x4
building a bogger
Old Oct 11, 2002 | 09:55 PM
taz3fan's Avatar
taz3fan
building a bogger
hi ford fans ... im building a 69 ford f100 shortbed 4x4,currently running 300 6cyl and four speed with granny 2hi 4hi transfer case 4:11 gears front and back mini spool in the back end, 31 spline axles running 33 12.50 15 wild country tires. radiator is in bed with elec fan cooling,, also added msd 6a box and new points and exhaust pipe thur the hood.... this is a mud pit starting at 6inches to 7 feet deep 100 or so feet long... havent tried it out yet in pit .. am i missing anything? dont want to waste money on something i dont need! please help me have i missed anything
Old Oct 12, 2002 | 12:52 AM
tellico racing's Avatar
tellico racing
building a bogger
Air down the tires ,put it in 2nd gear,rev it up and let er go!! As you begin to slow down work your steering wheel back and forth a little to try and grab some more traction.An upgrade to an 8 cyl would help,but I have seen the 6's run good.
78 F150 4x4
429 CID
Dana 44 spooled Front,
9"Locked rear,
5:13 Gears
17/40/15 Gumbo monster mudders
18/39.5/15 Swamper Boggers
BIG,BAD,and UGLY.
Old Oct 12, 2002 | 12:47 PM
FORDNUTTZ's Avatar
FORDNUTTZ
building a bogger
if you bogg down on your first try
then try low side of your t case
i run a C-6 with a 351C in the low side with 38's and 4.56:1
i put it in drive and take off
for you is alot differnt
i would try hi side in your case for tire speed
but dont know id your 6 will run them good enough in hi side though
and with a spool in the front if you go to bouncing be easy because with a spool in the front the long side will snap if it hits before the short side hit and the tires spinning under power
have done this a few times
just remember if you like me ( go till it breaks) then put it on the floor and go till yuo cant go no more or till the flag ma tells you to
good luck and let us know how it works out
Old Oct 13, 2002 | 12:35 PM
tellico racing
building a bogger
I think he has the single speed t-case
Old Oct 13, 2002 | 01:01 PM
85351ho's Avatar
85351ho
building a bogger
the infamous dana 21?
Old Oct 13, 2002 | 03:51 PM
FORDNUTTZ's Avatar
FORDNUTTZ
building a bogger
hmmmm i c
Old Oct 13, 2002 | 09:23 PM
taz3fan's Avatar
taz3fan
building a bogger
hi all thanks for the information .. its is a single speed tranfer 2hi neutral and 4 hi .. but i do have a extra tranfer case its 4lo 2hi and 4hi . ill have to scrape the grease off to see numbers on it ,and i dont have mini in the front end its open, just the rearend..one question what about weight in the rear.. you want to cut as much away from front to make it lighter right..........the reason i have pick this pickup and motor combination it is a mule .. have pulled two dead chevys hooked together out of a hole in 3feet deep mud in granny at idle in granny...mmmmmmmmmmmm love this ford
Old Oct 13, 2002 | 09:51 PM
FORDNUTTZ's Avatar
FORDNUTTZ
building a bogger
yea but in mud bogg racing its all keeping your wheel speed up without any rpm drop
not what you can pull
faster the tires speen the more elovation in the pit you will have and the faster th e tire the faster down the track you go
Old Oct 13, 2002 | 10:01 PM
taz3fan's Avatar
taz3fan
building a bogger
weight distribution front lighter and rear needs no alters?????????????
Old Oct 14, 2002 | 12:14 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
building a bogger
BaronVonAutomatc
Texas Chapter
Aug 2, 2015 02:21 PM
puroford
Jul 17, 2013 04:40 PM
LSUFX4
2004 - 2008 F150
24
Jul 10, 2004 09:48 AM
ivanribic
Offroad & 4x4
15
May 27, 2004 11:52 AM
Opiewan
Garage & Workshop
42
Jan 22, 2004 07:18 AM
