I was looking into buying gauges soon and can't decide if i want to get a 4 hole a-pillar setup or not for the trans gauge. I hear you guys say alot of how worthless the stock gauge is, but my gauge seems to move alot and not stay in one spot all the time like i here you guys say. if its a cool day or normal freeway driving it sits about 1/4 of the way. if its hot and i'm running around town it sits in the middle. Do you still think i need the aftermarket gauge? also where does the aftermarket gauge connect to? does it take over where the factory gauge gets a signal from and factory lays dead?
I agree.. the stock gauge is useless in my truck.. My Autometer gauge is way better and more sensitive to temp changes !! My a-pillar has boost, egt, and dp tuner in it... my trans gauge and voltage gauge are in the overhead pod !
There's a pressure test plug on the driver side of tranny. You just remove that plug and replace it with the temp sensor probe. Will not affect the stock gauge. I don't kow about the stock gauge because I don't have one, but the after market gauge will show the actual temp.
Trans temp is a must, but whether you do it or not I would go with a 4 hole pillar, so you can add future gauges.
I only have the 3 gauge pillar and am wishing I had got the 4 gauge.
Agreed with the above posts.... I went with the 4 pod mount with 3 gauges and am waiting on the funding (it's a little tight right now) for a DP tuner.
Dang and I thought I had a mess of wires under my access panel! What's the scoop on the "Ford Vehicle Security System" module?
Hey, at least it's a organized mess! I did it as clean and neat as could be done I think. Honestly, I don't know much about it. Maybe I should read the instructions!!! I know if I try unlocking and opening the door with the alarm set it starts beeping at me. I gotta use the remote to unlock. Besides that... worthless unless I am missing something. I cut out my stock exhaust with it armed and it never went off! Maybe I gotta adjust the sensitivity.
